LQ9/S475 83MM T4/LS6 CAM E85 dyno results
I actually sold this car a few months back, but the new owner shared some dyno results with me with I thought were interesting.
Combo is as follows:
*120k mile LQ9, heads never off, head studs, LS6 cam and BTR dual springs, CTS-V pan.
*Holley High ram, dont have any data on the fuel system although it had to be upgraded for the E85
*s475, 83mm, t4, 1.1, open down pipe for testing.
*Truck coils, BR7ES
*LS3 exh manifolds, 2.125" hot pipes, divided, (2) 38mm Tials.
*Ebay 3" A/A I/C, 3" cold pipes
TH400, Trans Specialties "low stall" converter, 8.8, 3.27 gear
Interesting thing is that this was on a Mustang dyno. At 7lbs it made 650hp (sounds high????), and on 18psi spring only it made a little over 800. 26* of timing. I asked for the dyno sheets which he said he will send. Nice #'s considering the small cam and "low" boost.
*Truck coils, BR7ES
26* is that normal on e85 @18psi? I know pump gas is way different which is what I'm used to but wow 26*. Good #s tho. 650 for 7psi does seem high especially on a mustang dyno.
Was thinking same thing. If it isn't verified timing it could be at a more normal timing setting in reality. Extra 120 hp with 11 more psi doesn't seem normal either. I'd still be happy with #s no matter what timing or psi says. Lol
The small turbine wheel should be choking at 18 psi on a 6.0 so that number doesnt surprise me. 650 at 7 psi is crazy good for an engine that shouldnt make more than 400-420 FWHP NA. The best case should be 650 at the flywheel or about 550-560 RWHP with a 16% drive train lose. Must be nice to be that dude, huh?
Psi. We shall see what kind mph it pulls. It did run 132 mph at 10-11 psi when I had it. RW was approx 3400+ with my 200lb *** in the car.
