Twin s366's injectors?
Old Aug 4, 2017 | 09:31 AM
LilJohn's Avatar
Size your injectors for the air that you have. You have 1600 hp worth of turbo roughly flywheel. Do the math on how much injector it takes to fuel that much power.
Do 40mm JGS's or 44mm in the tial 56mm in the precision pair of 38's is pushing it a little too hard.
Old Aug 9, 2017 | 03:23 PM
Rob07002's Avatar
Is there a calculator for correct sizing?
Old Aug 9, 2017 | 09:02 PM
Dennis5374's Avatar
Fic 127s on 93 or id 1300s
e85 will need a lot more .
Old Sep 1, 2017 | 06:02 PM
Rob07002's Avatar
Reading now that bosch and siemend injectors won't work with oxygenated fuels like VP and CAM2.
Old Sep 1, 2017 | 07:49 PM
slowlsx's Avatar
Got a set of FID1300's with less than 100 miles of interested, make you a good deal. Should be more than capable of what your goal is. 127lb Injector should take you to 1200-1300whp on gas
