Is my car the right car?
2002 Ws6 9k miles
-Trick Flow ported heads
- Comp Camshaft
-Harland Sharp rolloer rockers
-Fast 90mm manifold ported
-Nick williams 90mm throttle body
-Slp air intake
-Slp under drive pulley
-Rk T56 Built
Kooks True dual full exhaust
-Motor and Tranny urethene mounts
-Moser 12 bolt rear
-All rear suspension is bmr
-Walbro 400 fuel pump
-F.I.C. Injecters 43lb ( I know these would need to be changed)
So what do you guys think?
It's really just a street car, It'll probably never see the track ( as sad as it is ).
Threshold... I understand things break, but I would like to have the thought I could get in and drive it where ever I want without it breaking down.
No It is deff not a daily driver, my daily commute is 50 miles round trip so it usually gets driven on sundays.
Often, you may need to relocate the alternator as well. One of my personal pet peeves about turbo kits is the fact that many people here don't connect the exhaust system and instead dump the exhaust out of a hole they cut in the front bumper. Between that and the A/C hardware removal I find the finished product of most turbo builds on these cars distasteful at best. Finally, by the time everything has been addressed adequately, you are at the same basic price point as a supercharger kit would have been. The installation is much more difficult and the results aren't as good aesthetically speaking in most cases.
From a performance standpoint, I think it's possible to make more power on turbo setups but you can make a lot from a supercharged engine. More to the point, you can make a lot of power from a supercharged setup and not hack the **** out of your car, compromising safety in a crash event and making it look hideous. You can retain your air conditioning and a more OEM appearance. Of course, intercooled supercharged setups may box you into a similar position when it comes to the intercooler, but you won't have to ditch your A/C or hack up the radiator support.
I think a clean return to stock is actually possible when uninstalling a supercharged setup and next to impossible when dealing with turbocharger kits. That said, you can accomplish a turbo installation cheaper if you buy el-cheapo ebay pipe kits and turbos. I would personally wait until someone puts up a Vortec or ProCharger system in the classifieds section and pay less than half price. The only problem there is that you normally have to hunt down one or two parts from the kit that weren't removed when the system was taken off the car it was installed in the last time.
A final note, a smaller turbo kit may allow you to avoid standing the radiator up and you can run the exhaust out the back of the car, but I believe you will lose some ground clearance doing that. Intercooler installations always end up looking like hack jobs, but that applies to both setups. Though you do not need an intercooler with a supercharger even though it's a good idea to go with an intercooler.
