Some passes after multiple changes finally
Old Aug 16, 2017 | 01:13 PM
slowlsx's Avatar
I'm at 50 base, and saw 97% at the shift.
measured fuel pressure was 66psi, so it's not rising 1:1. Boost was 18.
i was also 10:1 AFR there, so leaning that will lower the idc as well
Same position as me sounds like but I'm already 11.0-11.2 AFR so there isn't much room. I'm going to raise fuel pressure, if pump can't keep up I'll add an inline AEM or Bosch 044
Old Aug 17, 2017 | 09:40 AM
RonSSNova's Avatar
Originally Posted by 93camaro_zzz
Man, the NEW injectors are already at 97%? That's unfortunate. Hopefully that scaled back quite a bit with the AFR change. Glad you got out with it Ron. I'm sure it was a fun time. Mine will actually be headed back out for the first time in 18 months in the next 2 weeks. First have to do some tuning, and schedule a dyno appt.
Hey man. Good luck! I didn't realize you had been away for so long. I guess I don't pay attention! 😊
Old Aug 17, 2017 | 09:42 AM
RonSSNova's Avatar
Yeah, I should have gone for the 1700's. Oh well. I think I can hit my goal with what I have.
Old Aug 18, 2017 | 04:07 PM
Nitroused383's Avatar
Glad to see the new intercooler is working well! Leaning out the tune will probably put you around 80sh duty cycle or so. I run 127lbers too and with 55 base pressure and dual 450's on 20 lbs I see 87% IDC at 7200 rpm with 11.6 afr.
Old Aug 18, 2017 | 11:47 PM
RonSSNova's Avatar
I'll know tomorrow. I'll tweak the tune from last weeks data, set up the boost by gear deal, raise the base to 53, and mow over the imports!
It's a Red Door Meet.......imports galore
Old Aug 19, 2017 | 02:59 PM
slowlsx's Avatar
Only adding 3psi to the base? Figured atleast 60
Old Aug 19, 2017 | 04:30 PM
RonSSNova's Avatar
I added five. Also leaned out the fuel, it was way rich.
trying to limit the pressure to below 80 psi when I turn the boost up to 25 in the future. I've read that's about the limit for the Holley pumps.
i do log fuel pressure
Old Aug 19, 2017 | 05:41 PM
truckdoug's Avatar
damn i was hoping to make a bunch of passes. oh well, next week then
Old Aug 20, 2017 | 02:13 AM
RonSSNova's Avatar
Well, the boost by gear didn't work. I guess I don't understand the 37 pages of bullshit published with the eboost 2.
Old Aug 20, 2017 | 08:59 AM
truckdoug's Avatar
quoted for truth!
Old Aug 20, 2017 | 09:38 AM
Bad Apache's Avatar
That made me laugh! Not at your hardship, but the 37 pages of dump needed for a boost controller.
Old Aug 20, 2017 | 11:59 AM
  #32
truckdoug's Avatar
yeah navigating five billion options and menus with three buttons and a 3 digit led display is some fucked up ****. worst UI on any motorsport product i have ever seen.
you'll be seeing seeing mine in the classifieds here shortly lol
Old Aug 20, 2017 | 12:04 PM
  #33
slowlsx's Avatar
I see!
Turns out I'm at 50psi base pressure. Right now at 12.5-13psi with 14* of timing and low 11's AFR I'm at 95% IDC at the top of my shifts. Calculating about 780WHP to go 113 to the 1/8 at 3900lbs. If I bump my base to 60psi I wonder how much extra fuel that will supply? Is there some type of calculator out there?
I see tons of guys making 950-1000whp with this Holley 12-1800 I'm no where near
Old Aug 20, 2017 | 05:23 PM
  #34
RonSSNova's Avatar
I see!
I have the 12-1800 and the little half brother, I forget the part number.
The aux pump comes on at 15 psi boost.
I target 11.2:1. I'm sure it would be fine at 11.5-11.7. That will add a little headroom.
With raising the base to 55 and leaning the fuel to commanded, I saw less than 80% idc last night.
One thing required is a good voltage supply. The pumps drop off if the volts go low, so monitor that as well. I see 13.9v throughout the run.
My buddies wagon has serious voltage issues. It falls below 12 during the run negating the boost referenced FPR. I'm pretty stumped on his car. It's wired just like mine........
We finally added a pressure sensor and logged it last night.
And even with that, it ran 8.97@154 last night and 12:1 AFR........I can't reign him in......he only knows turn it up.
It's at 133% IDC.........
BTW......track was slick last night as usual. 1.6 60 ft first pass leaving at 3psi.
So I put the 275 pros at 14 psi. Next two hits were both 1.52. Still sad.....but it controlled the spin.
And I short shifted it every pass but needed to control the spin.
Old Aug 20, 2017 | 05:28 PM
  #35
RonSSNova's Avatar
Somebody has to know how to do what I want. I do not want to have to do it with a button run by my finger. I'm enough of a spaz on the shifting as it is. Especially if I'm chewing gum.......
I want it to do it by itself.
I'm grounding the orange wire with the car in first gear. When I shift to second, that switch un-grounds and the next switch grounds the green wire.
So it should go from boost group 1 to boost group 2. Both are set up.
It stays in boost group one......
Old Aug 20, 2017 | 05:42 PM
  #36
69-chvl's Avatar
Ron, let me know if you figure out the voltage drop situation. Only thing I didnt do was replace the reman alternator(s) with a ~300.00+ unit.
Old Aug 20, 2017 | 06:08 PM
  #37
slowlsx's Avatar
So you went from 50 base to 55 and dropped to under 80%? What were you at previously?
Old Aug 20, 2017 | 06:20 PM
  #38
RonSSNova's Avatar
97%.
Remember, I was dead fat last week, so I corrected the VE table to fix that.
Spot on at 11.2 AFR now.
But I was only at 17psi......it's going to get a bit worse when I crank it up.
However, the boost referenced FPR should make it not too bad.
Old Aug 20, 2017 | 06:23 PM
  #39
RonSSNova's Avatar
Neither did he. Just got another re-man truck unit.
I'll rig up a voltage divider to connect to the alt output so I can log that with HPT. Need to start at the source.
I have a powermaster 14.8v unit. It works nice......as I had similar issues before.
Old Aug 20, 2017 | 06:25 PM
  #40
Cwarta's Avatar
You guys are scaring me with all this talk of issues and Boost controllers. I just bought my first one, the pulse/boost leash combo and I'm nervous to dive into it lol
