Powerglide with turbo 5.3
Old Aug 13, 2017 | 09:13 AM
Stonerracing's Avatar
Default Powerglide with turbo 5.3
Im getting ready to buy my third member and i was wondering if this setup would work. Or would it be a dog. Starting line ratios are calling for 9,10,11 range. This is pretty low at 6.25..thnx
28" tire
1.76 powerglide
3.55 rear gear
3000 stall
500-600 rwhp
Looking around 6000-6200 max rpm.
Old Aug 13, 2017 | 09:22 AM
3 window's Avatar
Converter's gonna make all the difference in the world. Whose converter are you running? What are you basing the "3000 stall" on? Advertised or actual?
Old Aug 13, 2017 | 10:35 AM
im basing it off of advertised. Ill probably run the freakshow performance converter with a transbrake.
Old Aug 13, 2017 | 11:11 AM
3 window's Avatar
I'm not familiar with the freashow converters. I've got a PTC and when I ordered it, I explained my intentions/setup and it does EXACTLY what they said it would. My point is when you order, make sure you tell them as much info as you can with accuracy. Don't inflate power numbers, guess on weight, etc. and you should be good. Boost makes a lot of torque, and I wouldn't hesitate for a minute to run a glide behind my 5.3. But again my converter might have to be adjusted because it was set up with a th400 in mind.
Old Aug 13, 2017 | 05:51 PM
My last build i had a 1.76 powerglide with a 4.88 gear. 5500 stall. That is much closer to the optimum starting line ratio. But everybody keeps saying thats to low for turbo car. What gives!
Old Aug 13, 2017 | 06:21 PM
3 window's Avatar
Contrary to thought processes of long ago, turbos make tons of torque.
Old Aug 13, 2017 | 08:33 PM
yenkomike's Avatar
I run a 1.76 glide with a ptc 3200 converter and a 3.23 gear and 28" tire and it works good at my low to no prep track. 5 psi launch will get me 1.50 60' times and if traction was not an issue it whould go a lot faster.
a 3 or 4 psi launch with a 6000 rpm shift will get me in the 9.90 range at 3600 lbs at 16 psi boost.
Old Aug 13, 2017 | 09:36 PM
tblentrprz's Avatar
weight and target use (1/8, 1/4, street, etc.) needed to optimize gear
Old Aug 14, 2017 | 01:25 PM
Forcefed86's Avatar
3.10 gear, 30" tire, 1.76 glide. 8 sec quarter miles and 1.3x 60's with no drama. 18 mpg on E85 @ 3200lbs. PTC 9.5" converter custom spec'd by them. I'm sure I could have gone quicker with a shorter gear, but without OD, it sure is nice cruising with a tall gear.
Old Aug 14, 2017 | 02:43 PM
DBRODS's Avatar
PTC is worth the extra money, stay as far away from freakshow as you can. Nothing but junk.
Old Aug 14, 2017 | 10:35 PM
Game ova's Avatar
"Freakshow" converter just SCREAMS quality. Will probably end up making a freakshow out of your motor and transmission. I know it sucks throwing down big money for a converter, but it's worth it.
Old Aug 14, 2017 | 10:57 PM
silvea's Avatar
Out of curiosity is 500-600ho enough to go powerglide over turbo 350? It seems like a little extra gearing could be helpful.
Old Aug 15, 2017 | 08:43 AM
3 window's Avatar
it's the torque too. Powerglides "operate" a little differently than a 3 speed as far as relying on the converter to work well.
Old Aug 15, 2017 | 08:50 AM
Forcefed86's Avatar
Around 550-600 crank th350’s get expensive to keep alive. Money ahead going to a th400 if you go with a 3 speed IMO… A glide is easier/cheaper to maintain and work on in my experience though. Esp around 600hp in a light weight car.
Old Aug 15, 2017 | 08:58 AM
ls13ater's Avatar
What turbo? I had a friend with a 1.76glide/5.3, on3 76 with a freakshow in a gt car would 1.36 60ft off footbrake, 6.20-6.30 regularly, have another friend with a coupe 4.8/ 1.8 glide, s483 and a ptc that would 60ft 1.4x off transbrake and take forever to build boost, put the freak show in it and it would not even build boost, the add stroke of the 5.3 and smaller turbo leave harder as long as the converter is lose enough to get it in the power but not to loose to just blow threw it , converter will always make the difference
Old Aug 15, 2017 | 09:18 AM
yenkomike's Avatar
if you plan on making enuff power to go low 10s then spend the money on the converter. I have ran a few freakshows and they hold up fine on 5 or 600 hp but we have broken 2 converters on 6.0 turbo cars running 15 lbs boost or so.
Old Aug 15, 2017 | 10:00 AM
mightyquickz28's Avatar
I had a Vigilante TC restalled from 2800 to 4300 for my built TH350 and swapped gears from 3.55's to 3.08's, thinking it would load the turbo better and that the turbo's torque would overcome the gearing. What happened was that the shifts resulted in only a 200 to 300 rpm drop. ET/MPH was 11.3 @ 120mph. Talked to a few folks and they said "Get a PTC stalled for your application and put those 3.55's back in there". I did and went racing last Wed night in upstate NY. Off the highway, onto the track. 17psi in my M/T 315 drag radials. Running 2 psi off the brake, sixty foot was 1.5, ET 10.6 and MPH was just shy of 129mph.
Old Aug 15, 2017 | 12:08 PM
DBRODS's Avatar
I had the baddest glide and converter freakshow could build. It didn't even live on 18psi and 3 hits. Like I said junk, and everyone one I know that has used them has had issues.
Old Aug 16, 2017 | 05:57 AM
yenkomike's Avatar
I have seen a couple hold up well and 2 that didn't live more than 2 hits.so I'm with you spend the money and worry about one less thing.
the jarrett(stock48) speced yanks seem to work and hold up well.
Old Feb 3, 2019 | 11:01 AM
Buschlight's Avatar
What kind of power were you making yenkomike?
