2007 LQ4 - ok?
Old Aug 30, 2017 | 08:30 PM
Rob07002's Avatar
Default 2007 LQ4 - ok?
Thinking of pulling the trigger on an ebay LQ4
2007 out of a GMC Safari cargo van with 269k miles
I plan on refreshing it, so not too worried about miles so long as no major issues. Yard says it runs fine.
Question, aside from it most likely being DPW, are there any major differences between this and say an 04-06 LQ4?
Plans are twin s366's
Thanks
Old Aug 30, 2017 | 08:53 PM
badass68's Avatar
Depends on the price. I picked up a 09 ly6 with accessories and 98k for $945 shipped to my door. It was being sold as a core because it had a knock. Knowing ls motors, I figured it was a lifter and it was. Found it on car-parts.com
Good luck.
Old Aug 30, 2017 | 09:12 PM
Rob07002's Avatar
Good luck.
$700 shipped from Canada.
Is everything compatible with older LQ4's? Is it a bastard year and not supported by the aftermarket
Old Aug 31, 2017 | 06:02 AM
yenkomike's Avatar
I'm not sure about vans but the 07 classic trucks are 24x crank and the new body style are 58x crank .at liest the ones iv seen.
Old Aug 31, 2017 | 07:34 AM
01ssreda4's Avatar
07 was a switch up model for the trucks and could have gotten gen3 or gen 4, vans Im not sure. If its gen 3 it will be identical to the older models you listed.
Old Aug 31, 2017 | 08:10 AM
Rob07002's Avatar
Does it matter if gen III or gen IV?? 24x wheel vs. 58x wheel?
Old Aug 31, 2017 | 09:02 AM
01ssreda4's Avatar
That plus the cam sensor, cam design (no rear sensor pickup), and front cover design.
Old Aug 31, 2017 | 09:42 AM
Rob07002's Avatar
Can you tell a classic or Gen III from Gen IV by photos?
Old Aug 31, 2017 | 09:52 AM
yenkomike's Avatar
the crank sensor is black on a 24x and grey on a 58x. if it has 13 mm valley bolts and 13 mm exaust manifold bolts it has the gen 4 floating rods. if they are 10 mm it has weaker pressed on pistons and rods.
