Spark plug gap
Old Sep 1, 2017 | 05:36 PM
Ogoz23's Avatar
Default Spark plug gap
Hello guys , I have a 5.3 single turbo and I don't plan on going any higher then 13 psi with 92 octane. I'm running NGK BR7EF.. they come with a .028 gap .. should I leave that gap alone or change it .. thank you in advance.
Old Sep 1, 2017 | 05:38 PM
kingtal0n's Avatar
the boost and power output is low enough for you to experiment. Normally I would Try the larger gaps first (0.045~") , make sure you have a good voltage and battery and grounds etc... and hit it. If it blows out, it will be pretty obvious, and you can gap it down.
If you just want to skip all that then I would leave it 0.028"
Many will tell you they have run 15psi of boost on OEM 0.055" gaps
Old Sep 1, 2017 | 05:57 PM
Ogoz23's Avatar
I know this sounds dumb , but what I'm i feeling by the spark blowing out .. backfiring ?
Old Sep 2, 2017 | 09:20 AM
ddnspider's Avatar
Leaving the stock tr7 Gap (.028) at that boost level. The power that you'd gain from a slightly larger Gap will be negated by the annoyance of it breaking up under boost and you chasing your tail. Nobody runs more than like .035 Gap in here in a boosted pump LS.
Old Sep 2, 2017 | 11:59 AM
Ogoz23's Avatar
Ok I'll just leave them at .028 .. I don't want headaches
Old Sep 2, 2017 | 07:26 PM
Ogoz23's Avatar
I just checked the plugs and they come with a .022 gap .. I guess I have to open them up .. I never would of thought the gap would be so tight
Old Sep 2, 2017 | 07:28 PM
ddnspider's Avatar
That does not sound right for a tr7. You sure you got the right plugs?
Old Sep 2, 2017 | 07:36 PM
Ogoz23's Avatar
I have NGK BR7EF
Old Sep 2, 2017 | 07:43 PM
ddnspider's Avatar
Wierd I just googled and confirmed the stock Gap on those plugs should be 028. Either way just Gap them somewhere at 28 to 32 and you should be fine.
Old Sep 2, 2017 | 07:56 PM
Ogoz23's Avatar
Old Sep 2, 2017 | 09:31 PM
Ogoz23's Avatar
What can you guys tell me about this plugs besides being rich.
Old Sep 3, 2017 | 07:30 AM
ddnspider's Avatar
Nothing lol. I believe you don't need to make a single 1/4 mile hit and pull the plug immediately to have a general idea what's going on with it. You can drive the car a bit and still see what the engine is doing with the plug.....but that thing is too far gone. You can see the timing mark on the strap but not sure I'd trust that. And you have so much fuel and carbon on the threads you cant get a good reading of the heat into the threads.
Old Sep 3, 2017 | 10:33 AM
kingtal0n's Avatar
only thing I can say for sure is they should look much cleaner. After 20k they should still be sort of white-ish in some places if you tuned it open loop properly, or slight tan/white if you are using closed loop O2 control. The leanish cruise a/f ratio cleans up the plugs while you drive. the lip around (the circle part) will still be black but the center parts can be cleaned while driving at the right mixture.
here is a cheapy copper plug from an 122 cubic inch turbo engine @ 400rwhp, 93 octane (that would be like having 240 cubic inches at 800rwhp)
I drove approx 12k miles and checked:
nice and clean in the middle is a good sign. I ran it open loop 15.2:1 most cruise situations so its a bit whiter than you get when running closed loop.
The picture of the plug you posted looks like closed loop isn't working or the tuner has no idea what the a/f should be at idle and cruise.
Old Sep 3, 2017 | 12:07 PM
Ogoz23's Avatar
That was like 4 hours of idle trying to get the idle right I probably did like 30 minutes of actual driving
Old Sep 3, 2017 | 12:28 PM
ddnspider's Avatar
If thats idle, you need to work on that tune.
Old Sep 3, 2017 | 05:24 PM
kingtal0n's Avatar
I would start with tuning the normal driving because chances are to make normal driving easier you will adjust constants which will ruin any idle tuning you do in advance
