Run it or junk it?
Old Sep 7, 2017 | 10:54 AM
Nitroused383's Avatar
^ yup that skirt will get destroyed. 1/2" is a lot shorter. Maybe throw a 4.8 crank in it lol
Old Sep 7, 2017 | 11:17 AM
oscs's Avatar
It's a stock stroke build I don't see the piston getting anywhere near low enough to cause issue. I spoke with Erik and Brian with LME about it when shopping a re-sleeve quote and they both said run it as it.
Old Sep 7, 2017 | 11:52 AM
DBRODS's Avatar
Yeah the skirt gets no where near the bottom of the bore! Heres a stock stroke in a 6.0 block.
Old Sep 7, 2017 | 12:26 PM
oscs's Avatar
Fair enough
Old Sep 7, 2017 | 12:36 PM
asubennett's Avatar
Originally Posted by oscs
Fair enough
Test it with a 3.26 stroke (4.8) vs the 3.66 stroke see where the piston goes.
Old Sep 7, 2017 | 01:54 PM
DBRODS's Avatar
The piston at BDC will be the same in a 4.8 or 5.3. Shorter stroke and longer rod vs longer stroke and shorter rod.
Old Sep 7, 2017 | 03:36 PM
MY_2K_Z's Avatar
Hmm I believe you are incorrect here...
Old Sep 7, 2017 | 03:58 PM
Ratical's Avatar
You would be correct. TDC - stroke. It uses a longer rod to achieve TDC.
Old Sep 7, 2017 | 04:53 PM
DBRODS's Avatar
Sorry,
with stroke of 3.62 and 6.098 rod at 180* of crank angle is 3.62"
with stroke of 3.27 and 6.275 rod at 180* of crank angle is 3.27"
So the 4.8 would be 0.350 higher up.
Old Sep 7, 2017 | 10:34 PM
asubennett's Avatar
Sorry,
Right, and with a custom piston with less skirt, maybe he gets it to clear....either way, I wouldn't run the block. Sleeved stock blocks always break and break fast.....
Old Sep 7, 2017 | 11:06 PM
oscs's Avatar
You should just junk it... aka I'll come pick it up and run it for you lol
PM me
Old Sep 8, 2017 | 09:11 AM
  #32
oscs's Avatar
I slept on it and decided to pass on the block
Old Sep 8, 2017 | 10:51 AM
  #33
truckdoug's Avatar
probably wise. those situations are tricky, you can end up throwing a lot of good money after bad
Old Sep 8, 2017 | 11:24 AM
  #34
silvea's Avatar
Depending on your goals even free is a bad price. I was originally going to do a 5.3 build major budget friendly. Got a cheap 6.0 after machining costs and a forged rotating assembly with some ls3 heads it came in way over budget. I have a much more stout engine that will make much more power than I originally wanted which is cool, but it def delayed my build by a few months.
Old Sep 8, 2017 | 12:29 PM
  #35
coltboostin's Avatar
Garbage, that sleeve is going to rip the skirt off that piston.
Thats where Im at. I dont see how that would NOT be an issue for a skirt.
And, you can get full, known running motors for dirt. Does it have to be a 370? With a 1000whp goal, you can do this with a stock crank China rods and slugs reliably
Old Sep 9, 2017 | 02:40 AM
  #36
Blown06's Avatar
8 Second Truck Club
How would you have improved it?
If you are looking to build an iron 6.0, I have a spare over here that is in pretty nice shape. The cam bearings were still tight in it and it is a std. bore. I had the block baked and shot blasted several years ago and have just been using it for mock up purposes to make custom ****. If you are hard up for a block and having a hard time finding one, I'll sell it to you. Let me know.
Like I said, the block is 100% gutted. No plugs/cam bearings since I had it cleaned up.
