Run it or junk it?
Old Sep 6, 2017 | 04:33 PM
oscs's Avatar
Default Run it or junk it?
370 iron block looking for 1000whp. Run it as is or trash it?
Attached Thumbnails Run it or junk it?-photo623.jpg   Run it or junk it?-photo26.jpg
Old Sep 6, 2017 | 05:17 PM
turbotruck2007's Avatar
I would beat it like a rented mule ... but that's me... lol
Old Sep 6, 2017 | 05:25 PM
Ratical's Avatar
It depends what other parts are going inside. If it's a low buck build with stock heads then run it. If you are going to put high dollar crank, rods and pistons in or run high dollar aftermarket heads you don't want to take a chance with I would get another block!
Old Sep 6, 2017 | 05:42 PM
oscs's Avatar
Fair argument. Motor is getting a stock crank, budget rods and the typical -11cc wiesco pistons. It's about as budget as it gets for a 1000whp build.
Old Sep 6, 2017 | 06:17 PM
Ratical's Avatar
Stock stroke too so the short sleeve shouldn't be an issue and it's almost impossible to sell a sleeved block so you might as well use it.
Old Sep 6, 2017 | 06:21 PM
Turbo D's Avatar
That sleeve is too short for even a stock stroke. I would junk it.
Old Sep 6, 2017 | 06:29 PM
silvea's Avatar
is the block already a 370 or do you want to make it into one? I took a hurt 6.0 and bored it .030 over t make it a 370 and all is happy in the world
Old Sep 6, 2017 | 08:32 PM
MY_2K_Z's Avatar
You should just junk it... aka I'll come pick it up and run it for you lol
Old Sep 6, 2017 | 08:36 PM
truckdoug's Avatar
can you have that sleeve cut out and replaced correctly?
Old Sep 6, 2017 | 10:31 PM
oscs's Avatar
This is what I'm going to do unless it ends up becoming an issue upon assembly
oscs's Avatar
370 already
Old Sep 6, 2017 | 10:33 PM
oscs's Avatar
Not that I'm willing to look into
Old Sep 6, 2017 | 11:01 PM
silvea's Avatar
I wouldn't waste money on a sleeve for a stock iron block. They are a dime a dozen.
Old Sep 6, 2017 | 11:02 PM
silvea's Avatar
I mean if you are hell bent on using it you could bore it .060 over if the walls are solid.
Old Sep 7, 2017 | 12:00 AM
oscs's Avatar
The sleeve stops .500 short of the bottom
Old Sep 7, 2017 | 12:02 AM
oscs's Avatar
I'm pretty sure it will be fine. IIRC the rings aren't anywhere near the bottom of that sleeve on the stock stroke.
Old Sep 7, 2017 | 02:44 AM
Blown06's Avatar
8 Second Truck Club
Thats a **** poor sleeve job if I've ever seen one. I could do a better job with a roofing hammer and a half round file.
Old Sep 7, 2017 | 06:20 AM
truckdoug's Avatar
its not the rings that would concern me, but rather the piston skirt snagging the thrust side of the block when the crank angle is approaching BDC from 90*
it's your block and your call, but for reference: I'm about as cheap as you can possibly get when it comes to machine work and that sleeve gives me pause.
last hole I had sleeved was ~$200 maybe it's less in your area.
anyways, good luck bro.
-my 2 centavos
Old Sep 7, 2017 | 09:15 AM
oscs's Avatar
How would you have improved it?
Old Sep 7, 2017 | 09:18 AM
DBRODS's Avatar
Garbage, that sleeve is going to rip the skirt off that piston.
