sudden boost loss
Old Sep 8, 2017 | 07:00 AM
rt338b's Avatar
Default sudden boost loss
After logging a run I noticed it went from 10 lbs on previous run to 3 lbs. Log shows that after burnout no boost duty cycle. So I just hooked up without boost controller to have it around 9 lbs but only at 3lbs. Have pressure tested intercooler and all hoses and cant find a leak anywhere. Anyone have a suggestion what to look for as I am dumbfounded after putting 10 lb spring in and only making 3 lbs and then going to 17 lb spring and making only 7. Thanks in advance for any info.
Old Sep 8, 2017 | 07:05 AM
forcd ind's Avatar
Are you using tee bolt clamps on all the hoses-years ago I had one losing boost, one of the hoses was actually pulling off, but would go back in place so it looked normal-I switched to tee bolts and problem solved
Old Sep 8, 2017 | 07:08 AM
rt338b's Avatar
yes all t bolts as I pressure tested the line
Old Sep 8, 2017 | 07:30 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
What intake manifold are you using? Several years ago I was helping a customer down in Mexico City find his boost leak. It turned out he had internal cracks in his LS6 intake manifold. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Sep 8, 2017 | 07:34 AM
rt338b's Avatar
I am using the standard truck style intake
Old Sep 8, 2017 | 07:36 AM
LS1Tech Sponsor
I'd pull it off and check it out. Bob
__________________
Old Sep 8, 2017 | 07:40 AM
rt338b's Avatar
Will do as I have another day before dragweek only seems odd with only 10 lbs
Old Sep 9, 2017 | 06:47 AM
rt338b's Avatar
Well that didnt do anything , still 7 lbs with 17 lbs of springs.
Old Sep 11, 2017 | 05:27 AM
stevieturbo's Avatar
So history ?
Everything was fine until you tampered with the wastegate ?
So clearly the problem lies with work done.
Is the gate sealed when it is at idle etc ?
Old Sep 12, 2017 | 06:01 AM
rt338b's Avatar
So history ?
everything was fine until after the burnout only change was after datelog to see if boost controller was broke but it checked ok also
Pressure tested gate its on the money for opening at spring pressure with shop air adjusted to 9 lbs. pipe off wastegate and checking at idle and it is closed.
Old Sep 12, 2017 | 06:19 AM
if the valve is sealing correctly on the gate and you are not making boost, then you have major issues elsewhere.
But seeing as you say this "problem" only happened after you tampered with the gates...it would seem likely you have created a problem with the gates.
The most likely of which given slow spool and low boost symptoms are that the gate valve cannot be sealing correctly.
Does the gate discharge into the exhaust again or to atmosphere ?
And again history. Has this setup ever ran correctly ? How long for ?
Are you saying the problem occurred whilst racing but making n changes to the setup, or only after you changed the spring in the gate ?
Old Sep 12, 2017 | 06:49 AM
forcd ind's Avatar
I have wondered if shop air really would show a problem-while you have pressure, you don't have vol., or heat
Old Sep 12, 2017 | 12:07 PM
It's a pressure test, you dont need volume ( unless you had a massive leak...but then you'd be fixing that. )
