Jet Boat Procharger bracket question
thanks for your time!
Motor is an l96 6.0. Just a z06 cam for now since I had to remove the VVT and running holley HP.
Could you mount it above the alternator on the battery side of your engine. The corvette kit wouldn't be any higher than the throttle body on the hi-ram.
Here is the corvette location...
http://shop.brutespeed.com/05-07-Cor...stems_c600.htm
Here's the Corvette 8 rib bracket assembly, which requires both the sub and main brackets links below.
http://shop.brutespeed.com/ATI-3GKBB...-3GKBB-035.htm
http://shop.brutespeed.com/ATI-3GKBB...-3GKBB-030.htm
If you then want to convert it to the dedicated drive, here is the link to it.
http://shop.brutespeed.com/ATI-2GQSU...01-8-8-Rib.htm
Below is the harmonic balancer that is needed. Bob
http://shop.brutespeed.com/ATI-Perfo...ATI-917345.htm
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
