Twin Turbo 4.8 Results / Single 80mm Build
#221
Yeah it does look tiny. Its just some 2.25" I had left over from making the turbo hot side.
#222
Haven't updated in a while. Been waiting on a few things to come together. Was finally able to get most of the interior back in the car. I also found a good deal on a gen IV aluminum 5.3 block and crank, so I pick that up and tossed it together with some gen IV rods/pistons I had laying around. Hoping to have it all going in there the next week or so.
#227
Turbo Addict
Beautiful work sir, man that turned out nice...like you knew what you were doing lol.
I'll be curious to hear in car vids of that exhaust. I'd like to do that as well as it would not only save weight over what I have but be quiet when I want it to be and then flow when I need it to make power.
#230
The 148mph pass was about 18psi/12-13* and the 151mph pass was 20psi/11-12*. I don't have any back pressure data. It will make 9psi on the TB in about 2 seconds after going WOT, way better than last year. Was shifting it around 6800rpm and it was 7000-7100 out the back. Might need to change the rear gear back to a 3.27, its got a 3.55 in it now.
#240
Ever tried shifting higher? Say 7500 rpm? I keep thinking I need to rev mine out more after seeing all these record setting 8000+rpm SBE monsters. (and those are standard stroke 5.3’s) My 4.8 seems to fall flat with the LS6 intake around 6500ish. (BTR .660 duals, 217/222 @ 111 .56X w/ 1.8 rockers)
