Twin Turbo 4.8 Results / Single 80mm Build
Old 05-07-2018, 11:18 AM
  #241
svslow's Avatar
Looks like on the 9.18 I took it to 7200 on the 2-3 shift.
Old 05-07-2018, 11:41 AM
  #242
Bad Apache's Avatar
Nice results already!
Old 05-07-2018, 11:52 AM
  #243
7 Second Club
ls3fox's Avatar
nice results for the first time out did you ever wheigh the car?
Old 05-07-2018, 12:10 PM
  #244
Forcefed86's Avatar
Man I dunno that gear seems about perfect. Still on 255's? I’d almost think you could slap a china short runner intake on it, shift at 7500 and run it out the top. Should do 162ish at 7500 @ 5% slip. Then I’d know what to do next on mine if that worked well!
Old 05-07-2018, 02:21 PM
  #245
svslow's Avatar
This is on a 28x9 Pro Bracket Radial. The china intake idea has crossed my mind.
Old 05-07-2018, 02:39 PM
  #246
Forcefed86's Avatar
Ah gotcha... so that’s slipping a decent amount then? Like 10ish %? Is that the 10” PTC deal? Better converter might help quite a bit. Prob tighten up a tad with more RPM? Might try hygard or similar fluids if you dont’ already run them?
I feel like my 10” is holding me back on the mustang a bit. Cruise is def. more slippy than my 9.5” PTC on the RX7. I cruise around 400-500 rpm more at like speeds in the mustang. RX7 has a slightly shorter gear/tire ratio too.
Old 05-07-2018, 02:43 PM
  #247
408GT's Avatar
Nice passes man.
Old 05-07-2018, 02:52 PM
  #248
svslow's Avatar
I've got a driveshaft speed sensor. Slip was right around 8%. This is a Circle D unit.
Edit: Going off the time stamp in the data log, at 9.2s into the run (the 151.45mph pass) the slip was 8%. But when I actually let off it was about 5.5%. So it likes revs.
Twin Turbo 4.8 Results / Single 80mm Build-dfxiw3j.jpg
Old 05-07-2018, 08:47 PM
  #249
Lawhead's Avatar
Oh man, Makes me think my LS6 intake with the Stage 3 isn't really going to be the best......
Old 05-08-2018, 06:25 AM
  #250
svslow's Avatar
Have not weighted the car yet. I'm guessing its around 3150lbs fully loaded.
Old 05-08-2018, 06:27 AM
  #251
svslow's Avatar
I've got a 2.5 gallon jug of Hydard at the house. Just has some synthetic ATF in it now.
Old 10-02-2018, 09:37 AM
  #252
svslow's Avatar
Update - car is doing well. Made a bunch of passes this year so far and over 2000 street miles. Have been playing with the suspension a ton. Car has been in the low 1.30 60' range recently, still would like it to be better. Swapped out to a Pro Flow intake instead of the LS1.
It went 8.90 @ 154 back in June. A couple weeks ago I did soem 1/8 mile testing and went 5.63 @ 127 on 24psi. Still need to weigh the car, guessing around 3200lbs race weight.
Twin Turbo 4.8 Results / Single 80mm Build-gdwclnq.jpg
Twin Turbo 4.8 Results / Single 80mm Build-xhscs9a.jpg
Twin Turbo 4.8 Results / Single 80mm Build-mkeru1c.jpg
Twin Turbo 4.8 Results / Single 80mm Build-8kdwt0x.jpg
​​​​​​​XQBbmzt.mp4
Old 10-03-2018, 01:26 PM
  #253
Forcefed86's Avatar
Very cool! What are you revving it out to these days? 2-step RPM and boost level at launch?
Old 10-04-2018, 05:50 AM
  #254
svslow's Avatar
Been leaving about 4000rpm. Boost from 7-10psi. I just put a shift light the car, still playing with that. But I've been shifting around 7500 and it seems happy. Just went out the the track last night. This was my first time getting good 1/4 mile data on the intake swap. It picked up about 3mph on the same boost/timing over the LS1 intake.
DA was about 2500', been raining for a week straight up here. Crossed the stripe around 7400, coverter slip around 6%. 25-26psi/14*.
Twin Turbo 4.8 Results / Single 80mm Build-rjdbtwx.jpg
Old 10-04-2018, 09:42 AM
  #255
7 Second Club
ls3fox's Avatar
3 mph from an intake is huge. what kind of intake temps are you seeing?
Old 10-04-2018, 09:51 AM
  #256
svslow's Avatar
On that last pass it peaked at 173*. Was 105* when I left the line.
Old 10-04-2018, 11:38 AM
  #257
Forcefed86's Avatar
Great info, thanks! Man do I need to rev mine out...It just hangs at 6600 with this 14 stator PTC deal.
Old 10-04-2018, 01:51 PM
  #258
svslow's Avatar
I've been really happy with this Circle D. This is the 3rd season on it now and its not showed signs of holding me back yet. Its likes the RPM, slip just gets lower and lower the more I rev it. I bet it would be different if I had a 3.08 gear or something like that.
Another thing to note is that I am still using a stock truck throttle body on the Pro Flow.
Here is the RPM and converter slip trace. I have a speed sensor on the driveshaft to compare to engine speed.
Twin Turbo 4.8 Results / Single 80mm Build-iwuow2r.jpg
Old 10-06-2018, 05:48 PM
  #259
Forcefed86's Avatar
What alt. pulley are you running, looks huge. Any trouble with it charging at idle?
U still on oem head bolts? factory TTA spec?
Old 10-06-2018, 07:54 PM
  #260
Nismo Kid's Avatar
This thing is moving out. It's awesome to see a SVO getting love. Congratulations on the pass. Still rocking the btr stage 2 TT cam? This build is inspirational for me as a 4.8 turbo guy. You've gained another subscriber keep up the bad *** work.
Quick Reply: Twin Turbo 4.8 Results / Single 80mm Build
