4.8 76mm 7675 vs 67mm
Old Sep 18, 2017 | 04:16 PM
99NassauC5's Avatar
Default 4.8 76mm 7675 vs 67mm
I have 99 C5 with an aluminum 5.3 block and floating pin 4.8 rotating assembly, ls6 cam, ls7 clutch and 2003 C5 Z06 transmission and rear end.
I've searched for a while and have narrowed down to 2 choices the on3 ceramic ball bearing 67mm or the 2nd gen 76mm 7675 turbo.
My goal is a daily drive that makes something close to 600 or 700 max rwhp, smooth idle (ls6 cam) and not too much turbo lag but I also want to be able to spin it to 7k.
Which one would you recommend on a single front mount?
Old Sep 18, 2017 | 04:47 PM
svslow's Avatar
A friend of mine has a C5 with a 5.3 and a single S366 turbo. He made 650whp on 15psi. Very responsive set up.
Old Sep 18, 2017 | 04:48 PM
ddnspider's Avatar
If you want to rev it to 7k I wouldn't go with the 67. The 7675 will have more legs when being revved. Better tuning will be needed to get it to spool but it's a better choice.
Old Sep 18, 2017 | 04:52 PM
99NassauC5's Avatar
Thanks guys, reason I asked is because I was afraid the 67 would not be enough higher rpms and the 76 would be too laggy.
Old Sep 18, 2017 | 06:26 PM
slowride's Avatar
I believe that 67 only has a 65mm turbine so probably not ideal. Get a 7275 from turbonetics or pte if you want better spool. You can get a cast wheel pte for for cheap or the Borg's s366 or sxe's etc.
Old Sep 18, 2017 | 06:38 PM
Black_Sunshine_99's Avatar
My Turbonetics T7875 isn't too bad when it comes to lag.
Since I've started street racing it I've noticed it does have a little lag but nothing some light brake boosting doesn't fix lol.
It'll pull cleanly to 6,500 rpm on my H/C LS1, maybe higher but that's as high as I'll go currently.
My vote would be any variant of a 7675 turbo, T-netics, PTE maybe even VS Racing?
Old Sep 18, 2017 | 07:02 PM
sbcgenII's Avatar
76/75 will spool fine.
Old Sep 18, 2017 | 07:47 PM
99NassauC5's Avatar
I guess I better copy and paste the turbo specs from their website. It looks like the 76mm is a good match for my build. But I will also look up the other turbos previously suggested. Thanks for all the feedback guys.
On3 2nd gen 76mm 76/75 turbo
  • Anti Surge Compressor Cover
  • 4″ Inlet
  • 3.0″ Outlet
  • CNC Machined Billet Compressor Wheel
  • 1/8″npt Port For Boost Reference
Exhaust Side
  • 75mm Turbine
  • 3.0″ V-band Outlet
  • T-4 Flange
  • .96ar
On3 67mm ceramic ball bearing turbo 67/65
Cold Side
  • Compressor Wheel 67mm
  • .70 a/r
  • 4” Inlet and 2.5” Compressor Outlet
  • Inducer- 67.05mm
  • Exducer- 84.10mm
Exhaust Side
  • Exhaust Housing T-4 Flange
  • .96 ar Exhaust Housing Standard, .68ar Housing Optional
  • 3.0″ Vband outlet
  • Inducer- 74.5mm
  • Exducer- 65mm
Old Sep 18, 2017 | 09:43 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Since you have included a super mild cam and the words "daily driver" in your post, I would recommend the 67mm. Most of this forum skews much more toward racing than daily driving, so I doubt many others will share this opinion.
Old Sep 19, 2017 | 01:56 PM
99NassauC5's Avatar
I agree, I know 600hp is low to today's standard but enough for something I would like to enjoy driving every day without having to worry about breaking other drivetrain components.
I got in enough trouble with the stock LS1 by being accused by a cop for racing a bimmer I never saw.
Old Sep 19, 2017 | 03:30 PM
sbcgenII's Avatar
76/75 isn't a racing turbo on a LS motor until you have 2 of them. A 76/75 will be in a good spot at 600-700. A 67/65 would not be. You will have no problem spooling a 76/75.
Old Sep 19, 2017 | 04:23 PM
I had a TC7868 in front of my H/C LS1 and it was kind of annoying.
The power came on like a light switch and was really difficult to modulate.
The T7875 is way more linear and makes more power at a lower boost level.
I don't think the S366 is comparable to the TC7868 but that's just my input.
Old Sep 19, 2017 | 04:54 PM
99NassauC5's Avatar
I got a little off topic, sorry it still pisses me off until this day. I see your point.
