Inline oil filter for twin turbo setup, with new engine??
Old Sep 27, 2017 | 11:35 AM
  #41
Cwarta's Avatar
Thanks for the heads up on this, I just picked up a chunk of 3/4 tube. Going to tig it in my front cover and use the braided 12an hose I have
Old Sep 27, 2017 | 01:03 PM
  #42
Forcefed86's Avatar
Originally Posted by Nali6.2
fp makes a inline turbo filter. they are trick little pieces and small enough to fit anywhere
Problem with small filters is they can clog very easily and take out the turbo. Better to have no filter than a tiny one IMO.
Originally Posted by MEAN GTO
Thanks once again!
Sorry to sound so helpless here.... I'm pretty good with figuring out fittings for various types of plumbing and putting stuff together, but I've never worked with hard tubing other than non-flexible copper and threaded galvanized pipe. I can't even seem to find the 3/4" ID flexible aluminum tubing on Aircraft Spruce.
I am running all Russell Performance fittings and hose for my feeds and drains on my current setup, so I'm not running some cheaper eBay stuff that has smaller outlets than actual -10AN or anything. But maybe I can open up the -10AN male fittings in the oil pan a little more to use larger fittings and line from the turbos?? I haven't looked at the fittings in a while to see how much meat is left on them in order to confirm if they can be opened up some more, but I would imagine I should be able to open them up a touch more?
Thanks again!
They do not sell flexible tubing that I am aware of. Just 3/4 hard tubing. 3/4 tubing is AN12. Ebay sells the same.
I'd use some sort of flexible tubing at the pan instead of a fitting to allow flex if you use hard line. The system will only flow as much as the smallest point. So ideally you should have 19mm or greater the entire run, including fittings.
Attached Thumbnails Inline oil filter for twin turbo setup, with new engine??-ebaysleeve_nut.jpg
Old Sep 27, 2017 | 01:07 PM
  #43
pdxmotorhead's Avatar
Make sure the fittings that connect other pan are swivel style not fixed..
I plumb dry sumps with AN aeroquipe hose.. I never use hard line on big stuff,
it cracks too easy..
Old Sep 27, 2017 | 02:39 PM
  #44
Forcefed86's Avatar
Usually only cracks if you plumb it in a way it can’t expand and contract with heat (or if there is a lot of movement between the parts) Can’t do a direct run to hard fittings with hard tubing. It needs excess material (bends or waviness) for expansion/contraction. I plumb hydraulic lines on aircraft in Ÿ + hard line all the time. For a straight 10” run fitting to fitting we use 12-14” of tubing. With a gravity drain I use a coupling style connection on one end to allow for this without excessive “waviness” into the plumbing.
Old Sep 27, 2017 | 03:09 PM
  #45
Black_Sunshine_99's Avatar
So my thought is the diesel drain you posted with a 90' elbow at the pan utilizing a short piece of hose to join the two together to allow for thermal expansion?
Old Sep 27, 2017 | 03:45 PM
  #46
Forcefed86's Avatar
Diesel drain is flex tubing, so it wouldn’t make a difference either way. But that would work fine.
Old Sep 27, 2017 | 03:50 PM
  #47
I've seen what the aircraft stuff looks like, worked on some friends race planes,, I just gave up on the hard line on engine to frame connections, a sprint or late model twists like crazy under power, slams in to stuff, for -10 and -12 I just went to the braided stuff to stop the pain of repairs.. Very few runs on a car seem to work out without a stress point. Also -12 doesn't just fit as easy as say -8.
When you have 4 dry sump pickup hoses that all have to thread through the frame/cage etc to the pan..
Old Oct 1, 2017 | 09:46 AM
  #48
MEAN GTO's Avatar
How do you remove this valve??? Nothing in here is threaded. Thanks!!
Old Oct 2, 2017 | 10:12 AM
  #49
Forcefed86's Avatar
It's pressed in. little heat and an easy out works well.
Old Oct 3, 2017 | 12:25 PM
  #50
ElQueFør's Avatar
If you replace that bypass valve with a soft plug...... How can one be sure it won't came out??
Old Oct 4, 2017 | 01:05 PM
  #51
Forcefed86's Avatar
You can order a bypass replacement for less than $2 shipped. Fill the inside of the spring "cage" with JB weld.. Done. Or order the nice billet plug from improved racing.
The threaded insert you thread the filter onto holds it in place.
Attached Thumbnails Inline oil filter for twin turbo setup, with new engine??-plug1.jpg   Inline oil filter for twin turbo setup, with new engine??-plug12.jpg
Old Oct 4, 2017 | 02:16 PM
  #52
rotary1307cc's Avatar
Put a soft plug in with sleeve retainer and it isnt going anywhere
Old Oct 4, 2017 | 07:34 PM
  #53
ElQueFør's Avatar
Cool thanks guys. I'm gonna have to do that next time I have the filter off.
