L92 heads on LQ9 block
My current NA setup is a LQ9 block with LY6 rods and pistons. L92 heads and manifold. I am currently running the TSP231/236 but I know for a fact that would be the worst possible turbo cam with it's 111LSA and 11.5(?) overlap.
I recently bought a Turbonetics T76 .94ar and am in the process of getting 80# injectors and another 255 pump.
I've seen really good looking cams on BTR and LJMS but they all state "for cathedral heads"... and the LS7 or 9 would be great but they have the cam sensor on the wrong end.
I am not trying to spend $400 on a custom grind either. I know someone has done this before 1000 times.
Thank you in advance for your advice.
I'm not sure what your first sentence means. I can get a LS6 which many people run for about $129. Or if you meant the other way, a typical Comp cam is $429.
Don't dwell too much over the different cam profiles for cathedral and rectangle port heads in boost.
(hopefully that link works)
