new best with 5.3 micro build.
1.28 60'
5.88 @117 1/8
9.17 @146 1/4
stock 2005 truck engine
sbe with stock 799 heads ls9 gaskets, isky triple 12 cam,
microsquirt , deka 80s, vsr 88/83 t4 turbo , pump e85,
truck manifold 2.5 to single 2.5 pipe to turbo.
400th ptc converter
3.73 gear.
leaving at 11-12 psi boost 22.5 psi full boost.
So that turbo has the small turbine correct? And just so I u/s, you have (2) 2.5 hot pipes merging into (1) 2.5" pipe into the turbo? What size down pipe, and exhaust setup (if any)? Thanks Mike.
im really thinking about going ladder bar coilover with a 28 by 10 slick and getting rid of all the leaf spring stuff altogether.
