Dyno Results!
Old Oct 9, 2017 | 07:06 PM
Hypforlife32's Avatar
Default Dyno Results!
Whats up guys, i have some dyno results from a recent session afte i hurt the motor awhile ago. made a couple small changes and went back at it!
just a quick run down
- 408 ly6
AFR 210cc heads
Holley sniper
Nick williams 92mm
id2000s
Twin 450 pumps
MWC 9inch
Th400
9.5 ptc converter
s484
E85
Car made 1025whp and 907 tq - 25psi. 10-11 (edited -12 degrees peak) degrees of timing. pics and vids soon
Attached Thumbnails Dyno Results!-image1.jpg   Dyno Results!-image2.jpg   Dyno Results!-image3.jpg
File Type: mov
Old Oct 9, 2017 | 07:56 PM
silvea's Avatar
It seems like you have a ton left in that set up. I can't imagine 11 degrees of timing is anywhere near where it should be on E85
Old Oct 9, 2017 | 08:07 PM
Found out peak was 12 degrees. lol
Old Oct 9, 2017 | 08:09 PM
MY_2K_Z's Avatar
Nice! That's some serious power, I know every setup is different but ya 11* seems pretty low for a built motor.
Old Oct 9, 2017 | 08:35 PM
gtistile's Avatar
Can you show the whole graph?
Old Oct 10, 2017 | 08:36 AM
coltboostin's Avatar
Way to many variables to make that assumption. MBT is MBT
Old Oct 10, 2017 | 08:46 AM
necrocannibal's Avatar
Are those 4 bolt or 6 bolt heads?
Old Oct 10, 2017 | 10:12 AM
Ratical's Avatar
Nice numbers! Looks like you are not twisting the engine up either. If I read it correctly less that 6k?
Old Oct 10, 2017 | 10:19 AM
I can try and getit sent to me.i dont have a pic. it was in mph anyways.
Old Oct 10, 2017 | 10:20 AM
4 bolt heads.
revving to 7-7200rpm
Old Oct 10, 2017 | 10:27 AM
Originally Posted by Hypforlife32
4 bolt heads.
Wow. You didn't push any water at 25 psi? That's great news, I'm going to be pushing some 4 bolt heads up near there hoping they don't lift.
Old Oct 10, 2017 | 10:31 AM
Ratical's Avatar
Ah, that is more like it.
Old Oct 10, 2017 | 11:01 AM
nope, went to 80ft lbs on the heads and didnt have any issues. ls9 gaskets
Old Oct 10, 2017 | 01:03 PM
Awesome! Thanks for the info.
