"How Original".......Billet S480 Fox Body
Old 02-28-2018, 12:36 PM
  #101
Lawhead's Avatar
300 bucks assuming the old style head scared people......Not I lol
Old 02-28-2018, 12:40 PM
  #102
svslow's Avatar
Do they have the little notch on the deck surface? Those don't play nice with the MLS head gaskets. I had bad luck with the older heads like that.
Old 02-28-2018, 12:43 PM
  #103
Lawhead's Avatar
They make gaskets for it now Mahle has a set 54441 WS6store sells a set as well
The issue has been addressed with the aftermarket
Old 02-28-2018, 07:06 PM
  #104
Lawhead's Avatar
That poor mans racepak on my new Fiberglass dash
Old 03-01-2018, 04:19 PM
  #105
Lawhead's Avatar
The actual tablet I’ll be using and the adapter came in
This is what I have so far for the dash with things I’d like to see at quick glance
Old 03-06-2018, 12:19 PM
  #106
Lawhead's Avatar
Got the heads Back on and looks like we can move forward again
Old 03-13-2018, 02:29 PM
  #107
Lawhead's Avatar
Got the fuel system hopefully completed as far as Filters go
Going to feed both pumps with their own feed off the Cell because honestly it's the cheapest route LoL with 2 Ebay stainless filters for pre pumps and a Wix Post pump thanks to SVslow for the recommendations
Also ordered MAP sensor and a bunch of little things to hopefully get this car running by the end of the month!
Old 03-13-2018, 06:57 PM
  #108
truckdoug's Avatar
you gonna use the stock '98 fbody coils? i have some mounts i fabbed up to run truck coils in pairs, stood off the valve cover aways. they're yours for shipping.
Old 03-13-2018, 07:10 PM
  #109
Lawhead's Avatar
Interesting, wonder how’d they work with the On3 stuff previous owner had them mounted in the car with about 4 feet of spark plug wire to each plug....
Old 03-13-2018, 09:49 PM
  #110
truckdoug's Avatar
oh man at last mount them to the block and run the wires from under the headers, inside the car wtf
Old 03-13-2018, 11:58 PM
  #111
Lawhead's Avatar
Dude was a compete idiot if you couldn’t tell by this thread
How did you run the harness with the coils configured like that?
Old 03-14-2018, 02:25 PM
  #112
truckdoug's Avatar
I used the coils harness 100% stock, and it tucked away okay. plugged right into a stock length (but standalone) truck harness. used some nascar take-off wires.
looks like the driver side would work for you, but the pass side might require some work.
i'm using two DS truck manis, pass side has it down and forward, driver side has it flipped up and forward about where your header sits on that side.
Old 03-14-2018, 03:56 PM
  #113
Lawhead's Avatar
What the hell why not let’s see if it’ll work
Throw me a pm
Old 03-14-2018, 05:35 PM
  #114
truckdoug's Avatar
sheeit. i musta chucked them when the guy who bought my 806's didnt want them. sorry for strokin
Old 03-14-2018, 07:55 PM
  #115
Lawhead's Avatar
Damn lmao
Old 03-20-2018, 02:32 PM
  #116
Lawhead's Avatar
Few more parts rolling in......I'm extremely close to slapping it all together at this point got the rest of the fuel system purchased and fuel feed relocating it to the oil pan.
Shout out to SvSlow on the heads up on the Napa Filter as well
Old 03-20-2018, 02:47 PM
  #117
svslow's Avatar
Where are the pre-filters from? Do they look good?
Old 03-21-2018, 07:18 AM
  #118
Lawhead's Avatar
Just ebay stuff they don’t seem bad with feeding the pumps their own feed from the cell I’m not too worried think they’ll flow plenty they’re the same deal as the Napa filter can be taken apart and cleaned
Old 03-21-2018, 06:01 PM
  #119
Lawhead's Avatar
Well went to mount the pumps today and tried to do everything I could to mount them in the rear where most carb pump are and just don't have the room with the pumps and filters
Planning on mounting them along the frame rail. As long as the pumps are lower than the cell there shouldn't be an issue I wouldn't think
Old 03-26-2018, 02:59 PM
  #120
Lawhead's Avatar
Don’t find 200 dollar L33s every day.... picked this up thinking it’d be a back up 05 iron motor because I wanted one that was 24X
Go to load it up and see the 799s and kept quiet and went go unload it and realized
The block is aluminum
Quick Reply: "How Original".......Billet S480 Fox Body
