Turbo JY 5.3 Camaro 10.1 @ Mile High Bandimere
Old 10-17-2017, 08:07 PM
Jose93z28's Avatar
Default Turbo JY 5.3 Camaro 10.1 @ Mile High Bandimere
Heres A couple Videos of My 93 Z28 Turbo Camaro JY5.3 ls6 cam/4l80e stock 10 bolt diff, all stock suspension except rear lower control arms and relocation brackets and football inside rear right spring Sloppy Style Running Deep 10s @ Bandimere Speedeway Morrison CO, what do you guys think?
Old 10-17-2017, 09:48 PM
hfthe3rd's Avatar
Damn what's the whole set up ?
Old 10-17-2017, 10:33 PM
Jose93z28's Avatar
Stock 180k JY 5.3 untouched bottom end, ls6 cam stock 799 heads had valve leaks so grinded valves and added pac 1218 springs, GM 3 layer head gaskets, ls6 intake S475 billet T6 1.32 AR, 3” intercooler, 80# siemens deka Running on E85, EFI live tune by me, Stock rebuilt 4l80e Circle D 3700 single disk converter w Sloppy 3rd gear mod stock steel driveshaft and stock 10 bolt rear diff 323 gears stock suspension except rear lower control arms and relocation brackets.
The following users liked this post:
Jason Voegeli (08-24-2020)
Old 10-17-2017, 10:47 PM
MY_2K_Z's Avatar
Great job man! I love seeing such simple combos run so well.
How much boost?
Old 10-17-2017, 10:53 PM
Jose93z28's Avatar
How much boost?
Thanks its been lots of work to get it where its at but mostly because it has been a learning process throught the years, Its right about 17 psi or so I wanted to push more to hit the 9s but Im out of fuel system Ill like to build one over the winter and try it again with a couple more psi.
Old 10-18-2017, 08:42 AM
Hibs's Avatar
Great times, that's scooting at Bandimere. You'll definitely be faster at lower elevation, but if you're already out of fuel at Bandi you'll need to fix that before you go lower.
Old 10-18-2017, 08:48 AM
Gunters96lt1's Avatar
Very impressive!
Old 10-19-2017, 01:42 PM
ascastil's Avatar
Very nice. I noticed that Eclipse in the other lane was moving pretty good too.
Old 10-19-2017, 08:36 PM
sbcgenII's Avatar
Nice passes. Sounds like it is struggling in 3rd though. What rpm through the traps?
Old 10-19-2017, 10:42 PM
Jose93z28's Avatar
Yeah that eclipse was movibg forsure you dont see many that fast up here forsure was a good race.
Old 10-19-2017, 10:45 PM
Jose93z28's Avatar
Thanks Ill pull up my datalogs when I get a chance and report back to take a look at the rpms
Old 10-29-2017, 08:46 PM
a-low's Avatar
nice car. Got any engine bay pics?
Old 10-30-2017, 01:14 PM
Uneverknow's Avatar
Xgreat motivation for me to get my *** back out and finish mine! Great job!
Old 10-30-2017, 04:00 PM
3 window's Avatar
What’d you run in the 1/8?
Old 11-01-2017, 02:28 PM
Jose93z28's Avatar
Thanks heres one of the engine bay.
Old 11-01-2017, 02:32 PM
Jose93z28's Avatar
Old 11-01-2017, 03:21 PM
very clean !!!!
Quick Reply: Turbo JY 5.3 Camaro 10.1 @ Mile High Bandimere
