Too small turbo or too large a camshaft
Hello,
I m lookimg for advice on my set up. First turbo set up. I have a 2011 6.0 w/VVT, a 69mm GT45 turbo w/ 1.05ar T4 flange. I have a stage two turbo cam.from Brian Tooley Racing/LJMS (226/231 .605 - .598 and 113 +4 separation). Hardened push rods and dual valve springs. A 450 walbro lpm fuel pump with 80 lb injectors and a AEMmeth injection kit.
all going into a 4100# ,2005 GMC Canyon 4door crewcab 2 whl drive with a 4l80e trans 2900 stall and 3.73 rear gears. How will this combination work as my first build? What will be my limiting factor for boost? What can I expect for a rwhp? What will be the weak link for more hp? It's a street truck and I'm not sure what I will end up with for actual usable horse power. Any advice would be great.
Thanks
Ryan
Thanks
Ryan
Seems like a good list of parts. Major short coming in my opinion is the gt45. Its the turbine side that is small for a 6.0. I believe you need a larger turbine to keep the back pressure in check. Maybe a vsracing s480. That would be perfect they are the same size as a gt45 on the intake side and only a little bigger in the turbine side. Denman just made 1000hp with a 6.0 and a vsracing s480. Second most restriction will be the single 450 pump. M8ght do two of those instead.
Last edited by jordoza777; 11-08-2017 at 07:37 AM. Reason: Misspelled words/autocorrect issue
"in my opinion" the turbo is too small for a 6 liter engine......
either install 2 69mm or at least go with single 78-76mm with the largest "T4" exhaust housing available if you must do a "T4".
I am now working on LY6 truck turbo setup and i got the s480 clone with T6 Because the truck have enough room for it.
Good luck with your build
Thank you all for your feedback. Looking back I should have ordered the 78/75 from vs racing
what is the down fall of a too small of a turbo? The truck is up and running now, and at 8-10lbs of boost is a real.handful
hahahh
thanks again
Ryan
hahahh
thanks again
Ryan
