Single 66mm Turbo too small for LS1?
Hi, I'm pretty new to the LS engines and I'm looking to do a budget turbo build on my LS1 that is in my GQ Patrol 4x4, I'm not really looking for power just want a bit more torque and have that **** factor haha.
I can pickup a BorgWarner 300SX3 for a reasonable price and figured it's a bargain if it's not too small for my LS1, Has anyone got experience with a similar sized turbo? Thanks in advance.
I'm planning on doing this with a stock LS1 and no more than 7psi of boost.
Compressor Wheel: 66 mm inducer / 91.4mm exducer
Turbine Wheel: 80 mm inducer / 73 mm exducer 0.91 A/R
https://www.jegs.com/i/BorgWarner/156/177275/10002/-1
Alternatively if anyone has any sub $1000 turbo recommendations that would also be greatly appreciated.
Wouldn't that be too soon for highway cruising?
From my understanding you don't want to be in spooling range while cruising do you?
Thanks for the help so far fellas you all have been really helpful.
I don't know if you have driven a turbo vehicle before , but boost depends on how much you are loading the engine . You can have the engine revving at 5000 rpm and still be pulling a vacuum if there's no or low load . Your right foot controls the boost . As for fuel economy if you are cruising and staying out if it you'll get same , if not better than N/A .
https://ls1tech.com/forums/forced-in...s366-step.html
Andrew
If you only scrolled down a bit, you would have found this:
Andrew
Andrew
