Cable driven fuel pumps
Old Nov 10, 2017 | 05:15 PM
Ratical's Avatar
Originally Posted by dmracing
Here’s mine. Wanted to do it once and be done. Fuel pump drive on the left. Rear mounted cable driven Magnafuel 1000 pump.
Do you have a breakdown of the part numbers you needed? (brackets and such also?)
Old Nov 11, 2017 | 11:52 AM
asubennett's Avatar
Whats the price tag on all that after you're done?
I don't get the appeal... Seems like it would be 2-3x more expensive than going with electric pump(s)
Unless you are running methanol at huge power levels, cost VS performance doesn't add up. Any of the big boy $500ish electric pumps on a boost switch with an AEM380 to cruise around will make 1500-1600 on E85 for under under $650...
You clearly haven’t pushed a big boy electric pump on E85 for any period of time. 2 4303s were about out of steam around 1300whp on E85....electric pumps suck when pressures rise high. And they are loud as hell. And....if one in a ,multiple config situation starts to die when pushing motor hard, good chance something bad will happen.... belt drive is truly a do it once never think about it again.
Old Nov 11, 2017 | 04:01 PM
dmracing's Avatar
Exactly. Well stated
Old Nov 11, 2017 | 04:35 PM
mshadow's Avatar
What does “piece together” mean exactly?
The pump mentioned is $800+ buy itself. That’s without the $100+ pump bracket and $100+ pump pulley. The balancer is over $400, plus the balancer pulley to drive the pump pulley (which the price isn’t even listed $100?) Plus the bracket to mount the assy to the engine (price not listed? $200?). Plus the cable drive assy… I’m not seeing $1500 there.
When I said piece together you're able to mount a pulley off the front of a lot of aftermarket balancers which most people already have if they're making 1000+ hp.
MagnaFuel MP-4204 which does 8gpm is $550ish from Jegs/summit/etc this will cover all E85 applications if you're running on methanol you might go 12gpm for 2000hp
Cable is $300-400 depending on length
Mounts/Pulleys $300-500
If you use something like the ATI hub it does increase the price but its really about spacing and what works on your setup.
Old Nov 14, 2017 | 06:43 AM
cam's Avatar
cam
Anyone have any pics of a mech pump opened up? They are a gyrotor type yes? What size is the rotor? The more info the better so if anyone knows vane count, impeller width etc. All of that will help us dig up something suitable. Over the winter I might see what I can do here
Old Jul 26, 2019 | 12:17 PM
5.7stroker's Avatar
Bump. Did anyone ever put together a parts list for a cable driven setup to support big power using E85? Lines, regulators, pumps, brackets, fittings, etc?
Old Jul 28, 2019 | 02:10 PM
xXLindquistXx's Avatar
contact Robert Ette of AEI CNC he can get you everything you need.
Old Jul 29, 2019 | 05:55 PM
blackdak318's Avatar
Robert Ette or Motion Race Works
Old Jul 29, 2019 | 06:53 PM
5.7stroker's Avatar
Old Jul 31, 2019 | 12:31 PM
dmracing's Avatar
Old Jul 31, 2019 | 12:38 PM
dmracing's Avatar
This is his for the drivers side
