Lets talk intakes
Old Nov 30, 2017 | 09:28 PM
  #61
Rudy72's Avatar
Great stuff, nice quality build and always fun to see how much power gets made with mostly stock engines!
Old Dec 1, 2017 | 10:39 AM
  #62
DBRODS's Avatar
Originally Posted by jimmyg
What are you guys running for fuel/ injectors? E85? Beautiful build , the workmanship is phenomenal.
Thanks, yes its on E85 and using Holley 160lb injectors with a Aeromtoive red belt driven pump.
Old Jan 17, 2018 | 06:51 PM
  #63
Surtr66x's Avatar
Jus curious, anyone have anymore info on that sniper intake?
Im building a 408 stroker with a 78mm turbo, and running the fast 102 intake on a stock bottom end ls1. Im just worried the fast intake isnt going to stand up to the lbs on the 408 build.
Do they make a 102 sniper?
Old Jan 17, 2018 | 10:16 PM
  #64
MY_2K_Z's Avatar
A 78mm turbo is very small for a 408, what size exhaust turbine?
Old Jan 21, 2018 | 01:42 PM
  #65
Surtr66x's Avatar
its a 78/76..i know its small but i cant afford a 88 lol
Old Jan 22, 2018 | 01:30 PM
  #66
Forcefed86's Avatar
If you already know the distribution pattern of the current manifold... Wouldn’t it be easier to tune around that instead of starting over again with a new manifold, hood, etc… ? Most of them aren’t going to provide equal distribution… so you’ll end up doing individual cylinder trims in the end anyway to get it right. As mentioned add 15% to the whole tune, and pull 15% from the outer cyls as a starting point and get a good plug read. Better fuel would help too I'm sure.
