Lets talk intakes
Old Nov 23, 2017 | 11:20 AM
DBRODS's Avatar
Here is the race version.
Old Nov 23, 2017 | 11:26 AM
svslow's Avatar
That is amazing. Do you have pics with the front bumper on?
Old Nov 23, 2017 | 11:51 AM
DBRODS's Avatar
Old Nov 23, 2017 | 12:01 PM
brandon6.0's Avatar
Nice work dbrods. Mustang looks killer.
Old Nov 23, 2017 | 03:58 PM
3 window's Avatar
Beautiful work there! How’s it work on the street as far as coolant temps and IATs with the intercooler and radiator layin down like that?
Old Nov 23, 2017 | 05:10 PM
Taxman20's Avatar
I like the Sniper due to the lower profile. I would have to get a TB adapter for my 3 bolt TB and it doesn't have throttle cable mount location from what I can see.
Old Nov 23, 2017 | 07:15 PM
scottywheels's Avatar
I have a holley high ram and have tried others... But have not beat it.. I make over 1500 rear wheel with a single 88mm turbo so that's where I would go. spending $4500 on a mercel billet isn't even worth it.
Old Nov 24, 2017 | 06:54 AM
Taxman20's Avatar
Yea, I like the Hi Ram except for the fact of it being so tall. I am going to measure the height once I get the engine back into the truck to see if it will fit under my hood.
Old Nov 24, 2017 | 07:51 AM
rotary1307cc's Avatar
That's why dual plenum. Short and the best distribution you will find
Old Nov 24, 2017 | 09:26 AM
DBRODS's Avatar
It was 98* here when I finished the car and coolant temps never got over 187*. The intercooler is built with a garret core and on pulls to 155mph it never gets over 25* above ambient. There is actually more airflow over both in this position than standing up in a stock position. Its a street car and on 16psi its making 700whp and on 25psi 1040whp. Owner is getting used to the power before we turn it up more.
The lower section is boxed in for airflow.
Old Nov 24, 2017 | 09:53 AM
Bad Apache's Avatar
Beautiful workmanship!
Old Nov 24, 2017 | 11:37 AM
  #32
AnotherWs6's Avatar
I think somebody stole the Ford emblem off of that Mustang's grill.
Old Nov 24, 2017 | 12:03 PM
  #33
3 window's Avatar
The turbo ate it!
Old Nov 24, 2017 | 12:12 PM
  #34
helicoil's Avatar
What size charge pipe and what size TB were you able to get on that 'race' version Holley Sniper.
I had one of the very first ones, it wasn't a bad piece. Still seemed Chinese to me, I sent it back, but if I recall a 92mm TB opening.
Originally Posted by DBRODS
Old Nov 24, 2017 | 01:38 PM
  #35
DBRODS's Avatar
92mm.
Old Nov 26, 2017 | 05:07 PM
  #36
rkupon1's Avatar
Really nice stang, well thought out n executed! I could look at it for days...
Old Nov 27, 2017 | 01:47 AM
  #37
dmracing's Avatar
92mm.
So you mounted the throttle body upside down. Do you have any Pics of the throttle bracket holding the cable
Old Nov 27, 2017 | 11:44 AM
  #38
DBRODS's Avatar
Here are the only 2 pics I have of it. The uncoated pic the angle wasn't quite correct for the cable. In the coated pic it was changed.
Old Nov 27, 2017 | 06:02 PM
  #39
Gunters96lt1's Avatar
That mustang is beautiful!
Old Nov 27, 2017 | 06:05 PM
  #40
Taxman20's Avatar
DBRODS, What rpm are you hitting? I hear these lose bottom end a bit and have to be spun higher to get into the power. Im trying to decide between this intake an the Hi Ram. Of course I launch at 4k+ and am at 6k instantly on the track so it never sees below 6k when at the track. Forged bottom end so now I can spin it higher too. Was at 7k limiter, now that will go up.
I just like the lower profile on the sniper which keeps my truck hood stock.
