Would meth injection replace an intercooler?
If you are gaining 4+lbs of boost by removing the IC, you don’t have a proper IC to start with. 1-1.5 psi is the norm for “Acceptable” pressure drop across a properly spec’d core. Comparing RPM dependent blower setup to a turbo setup isn’t a “like” comparison either. Generally turning the turbo up another 1-2psi to compensate for pressure loss isn’t an issue.
Sure, in general 24lbs will make more power than 20lbs. Take that same setup with a properly spec’d IC and run them at the same manifold pressures. The intercooled setup will stomp a non-intercooled setup with a water/meth kit on it every time guaranteed
Water injection is NO WHERE NEAR as efficient as a proper A2A intercooler at dropping charge temps. It will NEVER get the charge temps below ambient either. The data your IAT sensor spits out when its saturated with fluid is crap… it’s totally useless information and does not accurately represent the charge temps.
How much fluid you are spraying? Most kits out there don’t spray near enough volume to effect the octane level in the cylinder much either. Think about the volume you are spraying VS total fuel injected, then divide it between 8 cylinders. The typical ebay water/meth kit isn't going to do diddly for your octane.
I’m not saying aux injection doesn’t have benefits, I use it on all my turbo setups w/ or without an IC. But It’s not an intercooler replacement… and shouldn’t be marketed as such.
What i would like to know is:
when cruising around, is the air going in from the turbo to the intake significantly hoter than the air entering it? Been looking for such data but no luck.
The war will see full boost very seldomly, perhaps 4-6 sec at a time. Shouldn't the design and decision to run an ic or meth based on the intended usage? Please understand that my car has no rollcage and being a convertible will never be on any track, this is 100% a hotrod, a fun cruising toy where building it is half the fun and i'm not looking for more than that. I simply don't want to detonate the motor for the few time
it will see boost and i don't want to mess around routing piping and fitting an A/W ic
unless it is absolutely necessary. Based and you guys imput it seems that a simple meth kit would keep things in check. Havent made a decision, might look into fitting somethin inside the dash since it has no ac or heat.
Without E85, I’d suggest A barrel style A2W. You can run a 5 gallon tank in the trunk and only circulate water through the IC while in boost. Should bring charge temps down near ambient similar to a A2A setup. Water/meth Inj. is so cheap and easy it makes sense to install a kit regardless.
Sounds as if you are arguing semantics.....water/meth is cooler charge temps AND octane. Intercoolers add NO octane.
You do know that a cheap ebay kit and the expensive Devils Own and such pumps are all the same right? They all flow the same amount of fluid, or pretty damn close. The ebay kit just don't come with the safeties and such, it has nothing to do with how much it flows.
As I was leaving Pat G's dyno the other day he told me this.
" In all these years of tuning I've learned to hate two things.....Mass Air Meters and Intercoolers" but, I'm sure he don't know what he's talking about either.
I will bow out and unsubscribe from this thread. It seems as if theories outweigh actual results.
Point is if your theory was right you wouldn't see the top names in racing using intercoolers... yet they all do. When you run baby blowers that are maxed out RPM wise a dinky intercooler can absolutly hurt performance and you may be better without. Run a good IC and a blower thats not out of steam and an IC will pick up power wise every time.
NONVTEC just posted up a great example on YB forums.
"A few years ago we had a car that slowed up a lot in the summer time.. Air temp on e85 was 160-170 with a a2a. I told them the intercooler needed to be replaced with some more efficient. We ONLY changing the intercooler it put up 15mph and lowered air temp to 120-130.. This was on a HIGH boost Honda 4 cyl. It went from 162mph to 177mph."
Water/meths benefits are in the combustion chamber. The intercoolers are before that. They serve different purposes.
But I’d suggest running an intercooler as well if you are shooting for 700HP on pump gas with small chamber heads. Esp. if you have flat top pistons. The added weight of the 5 gal (or larger) water tank in the trunk will make it more street friendly anyway.
Here's what he stated about the super cooler: http://www.yellowbullet.com/forum/sh...86&postcount=2
Raising octane usually does the same thing, less energy from the fuel per gram of fuel, and it is safer for the engine. Sometimes, raising octane is enough, and you can eliminate the intercooler all together.
IMO It goes: octane > intercoolers > water
-water is last because the system traditionally isn't as reliable, as it relies on a pump.
-If you have the best fuel, you don't need intercooler or water, unless the engine has an internal parts temperature threshold reliability issue.
Water has other properties which make it unique and part of a completely different set of reasons why it could or should still be used, even with proper octane or intercooling. Its last on the list of things you want to rely on for making the engine safe (being an aux injectable) but that doesn't mean it still won't find a place on a setup which could stand to benefit from it in other ways.
Inb4I get to explain it all again three times in increasingly longer posts to disbelievers....
First off your entire fuel system relies on a pump and injectors, so that point is moot. A water/meth pump can be just as reliable as your fuel pump.
Second, fuel will not make additional power, regardless of octane. The goal is to get cool dense air in the engine which will make the most power possible per pound of boost. Magic unicorn 300 octane fuel isn’t going to drop your charge temps any… so if you are running 400* charge temps a 25lbs the air will be much less dense than if you ran 25lbs @ 130* charge temps with an intercooler.
In short, if you’re looking for power an intercooler is the answer, period. Same goes with water/meth. Cooling the combustion chamber after the fact isn’t going to cram any additional denser cooler air in the cylinder. Much like above, with water inj you are mainly lowering the knock threshold. This may allow a bit more timing if you aren’t already at MBT timing, or allow more boost. But pound for pound cooler denser air is best at overall power production. Which is why the typical water/meth kit will never “replace” an intercooler.
Start getting into monster volumes of meth injected pre-turbo and things change a bit, but that’s not happening with the typical volumes most water/meth kits run.
