Head Gaskets
Old Jan 9, 2018 | 08:43 PM
Trucker82's Avatar
Default Head Gaskets
I have been doing fine with FEL-9292PT head gaskets on my 4.8L LR4 Boosted 10 psi around 450HP stock heads and bottom end.
Now Im upgrading to Trick flow ported heads, 302 duration cam, and same turbo kit 10 psi boost and thinking about upgrading head gaskets and was wondering if anyone knows of better? Made crazy power with the Felpro 9292 gaskets and I'm worrying for nothing?
And yes, I have looked on Trick Flow, Summit, and Felpro to but cant find definitive answers.
thanks for the help
Old Jan 10, 2018 | 06:11 AM
forcd ind's Avatar
A lot of guys use LS9 gaskets, some say the bore is to big below a 4" bore, but others say no problem, so who knows, lol
Old Jan 10, 2018 | 01:38 PM
Trucker82's Avatar
Default Thank you!
LS9! That' a good start! Thank You! Well even if the bore size is a little big, As long as the rings seat to the surface, at worst we will lose a smidgen of compression. No biggie.
Old Jan 11, 2018 | 06:43 PM
stevieturbo's Avatar
302 duration cam ?
Old Jan 11, 2018 | 09:24 PM
truckdoug's Avatar
thats gotta be a typo
Old Jan 11, 2018 | 09:39 PM
tblentrprz's Avatar
240* at .050"
30* more than needed.
Old Jan 12, 2018 | 06:19 AM
Trucker82's Avatar
Originally Posted by tblentrprz
240* at .050"
227 @ .50 on the Intake 241 @ .50 on the Exaust
Old Jan 12, 2018 | 09:45 AM
Mavn's Avatar
"I MAID THEESE"
That's wayyyy tobig of a cam
Mavn's Avatar
"I MAID THEESE"
I would put that in a Boosted LS3 lol not a 4.8
Old Jan 12, 2018 | 06:21 PM
Ron_Stoppable's Avatar
Run the correct Bore headgasket. You do not need LS9
Old Jan 13, 2018 | 05:25 AM
Yep...any stock GM MLS gasket will easily hold the power, so nice to run the correct bore size.
