“The S-2000” 2000hp S10 Xtreme 427” Twin 88mm
#123
Was bored, so I decided to bolt the headers on and Mock up the turbos. (They will not be mounted like pictures, but it still looks pretty cool. The headers are $195 Flowtech headers from Holley lol they actually are pretty good quality... the V-Band CLAMPS they send with them are literally a damn joke though
#124
Thanks guys! Got the Holley dashes mounted where I want them. I’m running two of them. One in the stock cluster location and another in the Double Din Radio location. I told myself when I started this build that I wanted to remove as many physical switches as possible . So the plan is to have one Holley Dash Dedicated for gauges and the other Dedicated for virtual switches I.e: Headlights, Digital Push to Start Push to Start ect. You can piggyback the Digital dashes through CAN
the Holley Dom.. CAN control lights and body electronics? or you're using a relay/fuse block with the Dom tied into it? (if that even makes sense..)
#129
Plus it would look killer in an S10 dash!
#130
Im still on the fence as to whether I want to roll with headers I bought or not. My initial plan was to mount the turbos in the grille, but part of me is wanting to mount them near the firewall (Like pictured) on each side, do to to the fact that so much weight wont be on the nose, and it would make it alot easier to run the exhaust Post turbo. Also having the Dailey dry sump equipped on the motor gives me the ability to get pretty crazy with turbo mounting because the pump scavenges oil from the turbos so efficiently. (Near the rear of the heads.) I decided to mount them up on the engine anyway. The turbos will not be mounted like pictured, but I currently don't have 90* pipes to face them forward to replicate how it would look in the truck. Lastly, Man that new Holley 12.3" dash looks sweet! I forsure Have it on my wish list! here's a few pics of it installed, the quality looks amazing! The pic with the dash with the aluminum inserts is a first gen S10 btw. The other two are from an Aussie car.
