boost build with alot of dumb questions about E85
Old Jan 29, 2018 | 08:46 PM
dans2000camaross's Avatar
Default boost build with alot of dumb questions about E85
ok so im planning a turbo ls build on E85. thing is i really dont know a single thing about it. what is a good setup for a 5.3 that has 799 heads, flat tops and 76mm turbo?
Old Jan 29, 2018 | 11:44 PM
jordoza's Avatar
I would recommend visiting the sloppy mechanics wiki. Then read the stickies at the top of the page. It will give you a ton of info. Read it all. Then come back and ask questions if you have any. Whats a good set up for a 5.3 with e85 and a 76mm is a very general question. Kinda like whats the best cam competition cams sells. There have been a million different ways to do what you ask. Even then i think there are seven different 5.3 and probably 40 different 76mm turbos. What ones are you asking about. What hp goal. What vehicle. What trans. What usage, all race, daily driver, cruiser, street brawler. All that will effect the combo that will be best.
Old Jan 29, 2018 | 11:45 PM
jordoza's Avatar
By the way i apologize if i come off like a dick. Im not trying to but according to a few people i d9nt have to try to hard to be one so sorry ahead of time.
Old Jan 30, 2018 | 05:34 AM
I guess my goal is 650 to the tires. Liquid to water intercooler. It's a automatic transmission car. I plan on using it for daily driver/Auto x and some drag but mainly Auto x. I really don't know what turbo I wanna run as I've looked at several 76mm units.
Old Jan 30, 2018 | 05:35 AM
Oh no your fine! All this is really new to me. I have a good general idea how I want the car to be just trying to get it there is the issue.
Old Jan 30, 2018 | 07:49 PM
ok so i read some of sloppy mechanics on fuel pumps. my questions are is there a way that the pumps can be used in the tank? will 2 walbro 225's be enough? i know i need 160lbs injectors. or should i use 2 in tank pumps to feed a bigger in line pump? im sorry for all the questions all this is new to me, ive never built a turbo LS car.
Old Jan 30, 2018 | 11:18 PM
jordoza's Avatar
I would go dual aem 380 or walbro 450. Its always best to err on the big side when it come to fuel systems i believ.
Old Jan 30, 2018 | 11:24 PM
jordoza's Avatar
Also check out this build thread
https://ls1tech.com/forums/forced-induction/1887441-99-ws6-twin-vs-3582-billet-80e-8-8-swap-made-bewsts-today.html
cwarta is the author and he is making boost footbraking with a stock converter with dual 3582 vsracing turbos. Bet there gonna spool stupid fast barring that if your stuck on a single turbo go vsracing billet 7875 8nstead of the normal starter 7668 everyone goes to and then moves to the bigger turbo in no time it will still spool really quick with a decent cam and converter.
Old Jan 31, 2018 | 07:12 AM
vettewreck's Avatar
I have twin Walbro 450s in my tank and 160lb injectors for my 5.7, twin 61mm build.
