Procharged LS3 Short-Block Options
Old Feb 3, 2018 | 04:23 PM
naws's Avatar
Default Procharged LS3 Short-Block Options
I have an LS3 that I'm going to be getting an F1A Procharger for and looking for 750-800rwhp. Rings will have to be gapped so at that point I may as well run forged pistons and rods and go with a 377. However, if I'm going that far I'm considering a 4" stroke for a bit more low rpm power but the Procharger adds stress to the crank and some say a compstar crank wouldn't work well with an F-series Procharger. Would a dragonslayer or lunati signature series be required? Would a 4" stroke cause more problems than it's worth? Should I just run the factory LS3 crank and run it as a 377? I'm going this far and don't want to cheap out potentially causing issues down the road. A 416 does sound more exciting than a 377
I'm changing my mind too often so some opinions would help get me set. It'll be pump gas with meth.
Old Feb 3, 2018 | 04:35 PM
Silver408z's Avatar
Since you are making power with the blower, the cubes are not as needed but you will have a better power curve with it. I personally had problems with a compstar crank and a f1r. At least do a dragonslayer. I do not know the lunati line but I am sure their entry level cranks with have similar problems. My new build is using the dart billet center weighted crank. It is slight more expensive than a dragonslayer but has more features and is a better piece.
Old Feb 4, 2018 | 07:52 AM
NitrOmm's Avatar
416, ABSOLUTELY !
If your concerned about Low end power, then it’s a no brainer. You will have no issues hitting you HP goal & TQ to match. 10:1 compression makes for a fun street ride as well.
My deciding factor was that I was already spending the money, time & energy with a new build ..... why not go bigger. I’m glad I did.
Old Feb 4, 2018 | 08:26 AM
rotary1307cc's Avatar
On a street car that will put on alot of actual miles a 4" stroke is perty silly on a stock block especially with a PA where it is not needed in any sort of way
Old Feb 4, 2018 | 02:26 PM
stevieturbo's Avatar
What weight of vehicle ? Auto or manual ?
Unless it's a particularly heavy manual vehicle where extra low rpm torque might be needed...just stick with stock stroke. Get a decent crank with stock stroke.
Old Feb 4, 2018 | 10:46 PM
naws's Avatar
It's a first gen camaro with a 6 speed. Possibly 3400lbs I'm not too sure. So it isn't something that will be daily driven but it is a street car.
2 comments for and 2 against a stroker.. Literally like the voices in my head lol
Old Feb 4, 2018 | 10:47 PM
naws's Avatar
Wouldn't a stock crank support an F1A? If i'm going with an aftermarket crank I feel like i may as well get the longer stroke version as what would I be losing?
Old Feb 5, 2018 | 04:44 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I wouldn't max out an F-1A on a stock crank, but for 750 to 800 rwhp you should be okay with the stock crank in my opinion.
Since this isn't a daily driver where you're planning on putting a ton of miles on it, you could go with a stroker crank. A 3.900 stroke is a good compromise for adding cubic inches vs engine wear. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Feb 5, 2018 | 10:44 AM
Detoxx03's Avatar
Don’t bother with a stroker. If you get a new crank just get a forged stock stroke dragonslayer. I’m still rocking the stock crank on mine after having a Procharger on my car for the last 6 years.
Old Feb 5, 2018 | 12:28 PM
I would recommend either stock stroke or 4" as opposed to a custom in between. Purely for the simplicity of being able to buy parts off the shelf when needed. And I say this as I'm running a 3.825 DS crank. When I wanted to replace pistons a couple of years go...as expected I had to get them custom made, there is nothing available on the shelf for this.
But as the longer stroke can weaken the crank, pull the pistons further out of the bore....unless you absolutely need that extra torque I just dont see it as being worth it.
The F1 is not a small blower, so entirely up to you and how long/hard you might use it as to how long a stock crank might last. It would probably be a very long time. But if building the rest of the motor, I'd just put a decent crank in there to be sure.
Aven an LS9 short motor would be a good base.
Old Feb 5, 2018 | 03:43 PM
Detoxx03's Avatar
If you don’t already have the headunit I wouldn’t just get a D1SC or D1X for your targeted power goal. Either will make what you want and be in the blowers efficiency range. If you may want more in the future the F1A makes sense cause it is capable of more than 700-800
Old Feb 5, 2018 | 04:04 PM
naws's Avatar
I don't have the blower yet so that was actually going to be my next thought.. Maybe I should just go with the D1SC or D1X over the F1A and stock crank. Save myself a few thousand while still hitting the power goals I'm looking for..
If I go the route of an aftermarket forged crank I almost feel like I have to go with a stroker or I'd be kicking myself if I didn't as the cost is basically the same.
Old Feb 5, 2018 | 04:11 PM
Buy the F1 and a steel stock stroke crank.
No reason to kick yourself for building a sound base to work from that will cover you for the future.
