4th Gen Camaro Street Car New PB 7.81@177
#85
I weighed the two and decided for being the same weight Id run the pro flo for a while. It is better constructed and it fits in my hood. I didnt seem to notice any difference in the two as far as rpm limit. The difference was a half of mph and the car was 30lbs lighter when it picked up the half mph with the holley. Also launched better and wasnt spinning. So its a toss up. Ill probably throw one on mid season and see what it does.
#88
Otherwise it didnt matter to me either way. I guess end of the day the pro flo has longer runners and I want to see if I can get anymore rpm out of it with the 3/8 pushrods. Even 100-200 more rpm would be great. Mid season Ill put a cam in that is made for this combo.
#90
With the aluminum block I bought a Melling M295HV. It seems to hold 5 more psi at cold warm idle with the same bearing clearances.
#99
Just for a freshen up. I bought all new fuel lines. Found a deal on some goodrich ptfe.
New pair of aem's with a straight 6oring-8an. No more check valves. Now we can see where these pumps completely run out.
I added a few pictures since people always ask me how the pumps are situated. twin 10an from tank to pump. 8an from each pump to the rear of each fuel rail.
