Factory ring gaps on a forged motor
I know I'll get crucified for saying that on here but why destroy good parts if you don't have to
probably open them up to 0.026" top and 0.024" second
that would probably give you enough leeway for 15psi
Clearly the engine is not built yet...only a fool risks too tight a gap unless they've tested to know for sure it will work, or they are doing the testing.
And all rings are not the same, and all pistons are not the same...so you cannot really compare one against another even if the number variances are very small anyway
I don't know why you think that, but that is not true. If it were, you would have to replace the bearings after torquing them up to check the clearance.
OP, my suggestion to open the gaps up are based on my own personal experiences. minimum factory gaps work great when everything goes perfect.
my experience has been murphy's law. a flaw in the tune. a bad tank of gas.
the extra ring gap is just a safe bet with little downside, and I think most experienced FI guys would agree with me.
good luck with your rig. a forged 347 with a blower will be all sorts of awesome!
Looks like you've done it wrong 600 times over 20 years.
Just because that's the way you've always done it doesn't make it right.
I mean what the hell do I know
I've only built 600 motors over the past 20 years
been doing it wrong all along
But in no way whatsoever does installing and torquing the bearings up render them unusable. That is just nonsense.
