LS6 intake and 3 bar map sen.
Thanks
Just make sure you take it apart and remove the runners before drilling or making any modifications for mounting a MAP.
So the one you have is too big for the hole? That is how I am understanding this.
Honestly the most creative thing I've seen people do is install an NPT fitting in the intake and attach the sensor to another fitting, so it can thread in or out. Seems better and more permanent than the o-ring or the crappy sleeve (which is what I have). I might get froggy if I ever find some free time and make something similar so I can delete my little backing plate I crudely made out of some steel I had laying around to hold it in and not worry about a vacuum leak.
Brother's car makes 1030rwhp on 24lbs of boost with this setup, zero issues.
