Economy blow off valve
They all seem to be the same, just diff names, lol.
Been like it past 2 years although not a huge amount of usage.
I did have one for a while after I changed from the Vortech to turbos, but I changed some pipework and couldnt be bothered welding up another flange etc for the BOV and just ran without.
Although also since changed to DBW in the middle of last year...so you can play with throttle blade openings a bit that would allow airflow but not affect the actual feel of driving when lifting foot off the pedal etc.
Main difference is softer springing in the SC application so it will open much easier, although some will also have a much higher diaphragm to valve ratio again to ensure more force to open/close it more easily.
SC applications are made to stay open at idle and cruise… Turbo stuff is not. Most of the super charger BOV’s that come with the kits are designed differently as well with a mechanical arm on them. They generally don't seal as well either and should be filtered.
