Brace s366's?
Old Mar 3, 2018 | 12:25 PM
baronsmith98's Avatar
Default Brace s366's?
Are s366's heavy enough to where they need bracing? I am running vbanded truck manifolds so basically just the vband clamp is holding it together. My motor is not solid mounted but I could make it if need be. My turbos are kind of far from the motor so I didn't want to brace them to the heads. Need ideas
Old Mar 3, 2018 | 12:26 PM
More pics
Attached Thumbnails Brace s366's?-img_0760.jpg   Brace s366's?-img_0762.jpg   Brace s366's?-img_0756.jpg
Old Mar 3, 2018 | 12:44 PM
Black89Z51's Avatar
You have to think as well, the further you get from the V-band the "heavier" they become due to leverage. Personally, I would at least put a rod on them to help support some weight, but if the motor rocks it could cause more stress than if they weren't braced.
Can you fab up a brace to the block somewhere to eliminate the rocking motion being detrimental?
Old Mar 3, 2018 | 01:18 PM
Yeh I think I'm gonna look into putting some kind of limiter on to keep the motor from moving. Might do what you said and at least put a single rod on them to help support some weight
Old Mar 3, 2018 | 01:44 PM
stevieturbo's Avatar
The weight of a turbo should never be hung off any pipework without any other support unless the manifolds are very compact and made from a sturdy material.
For a remote setup like that, the turbo must be mounted properly with no strain at all on any pipework.
Old Mar 3, 2018 | 02:23 PM
truckdoug's Avatar
i used some 2" x .125" SS strap. vertically it's stiff, laterally it's compliant with heat expansion, torque rock and frame flex.
Old Mar 3, 2018 | 03:19 PM
Do you have anymore pictures of this Doug and how has it held up?
Old Mar 3, 2018 | 11:29 PM
truckdoug's Avatar
its been fine. super simple last second idea has been totally great. held the heavy *** gt45 for 2 years and the 7875 for the last year
Old Mar 3, 2018 | 11:32 PM
truckdoug's Avatar
there's another one on my imgbb thats too big to attach
https://ibb.co/h3dDf7
Old Mar 5, 2018 | 09:14 PM
Ok I kinda just went full retard on the brace lol they actually turned out pretty nice. Now I am going to put in a motor plate and rearrange my alternator and power steering pump. The snowball continues. . .
Attached Thumbnails Brace s366's?-img_0930.jpg   Brace s366's?-img_0931.jpg   Brace s366's?-img_0932.jpg
Old Mar 5, 2018 | 09:31 PM
GotBoostRacing's Avatar
7 Second Club
Thanks for sharing pics for the OPs questions. I'm in a similar situation, so it helps me too.
To the op, you mentioned some sort of limiter. I'm going to give this a shot. Granted I have access to the front of the head. Just an idea.
Old Mar 5, 2018 | 10:26 PM
brandon6.0's Avatar
If u solid mount the turbos to the frame u need some type of flexjoint in the piping. U wouldnt need any engine bracing or plates.
Old Mar 7, 2018 | 09:03 AM
Ratical's Avatar
Looking good sir!
