Stock lq4 vs a stock lq9 with rect port heads
my 6.0 ls3 combo has a custom ljms spec cam, looking at it it doesn' scream turbo cam ....but it works. it' a 111+4 cam.
ljms knows turbos
my combo makes a ton of torque.....loss of bottom end power is a non issue
ljms knows turbos
My 70 Nova made 441 rwhp (uncorrected for altitude) with a bone stock LQ4, 76/65 turbo at 7.5 psi, non intercooled, 94 fuel and spraying windshield washer fluid for intake temp control. It is already way more power than you can hook on the street.
Jasonnova... yeah I’d buy a real good turbo cam for either engine, I like hearing with the big heads, torque loss is mute...
Slarsen... that’s not bad and any idea what it did with no washer fluid injection?
New school... I read that about building it that way and with less boost still make great power.
Looks like I will build the lq9 ls3 head setup with a good cam and then upgrade the turbo also if needed at the same time.
Never ran the car without the washer fluid spray. It is just there to keep intake air temps down. At 7.5 psi, I do not think I actually would need to use it. More of a precaution than anything and so little is used. No intercooler so this is my IAT control.
