70 Split Bumper 5.3 turbo build question
Good water/meth kit would be a plus. Fuel system that can handle E85 would be even better.
Th400 and a tall gear would be nice. I’m not a fan of the huge heavy OD transmissions. Don’t need it with a turbo build most of the time. Plenty of power to pull a tall gear. I run a 2.73 and Th400… will do 140ish in 2nd gear. 3rd gear becomes like an OD. Also no need for trans control then. But you do need a good converter IMO.
Go with the LS6/1 and a factory TB and be done, the 4L60 gets a bad rap but if you're not making crazy power a budget built 4L60 will work.
Honestly I'd listen to these guys though and go TH400 with a high rear gear, lots of guys around here do it because the OD's kept giving them issues and they street drive their rigs frequently.
Also, like others have said, get rid of the 4l60 unless you like your car parked/broken
