Air Filter for Turbo?
i also ran it on and off on the track it was within a couple hundreths both runs. Faster with filter. But that really doesnt prove anything. If the filter is big enough to not be a restriction i think youll find the same results i did. If its too small then yes it will pick up power. Have i tried to small of a filter no but my common sense powers tell me my guess is right.
Looks like some people did pick up not only power, but also were able to make more boost when they removed their filter. Stevie also posted in this thread from forever ago lol.
http://turbo-guard.com/dyno-results/
the one I got from AFE even says I can wash and re-use it. No oil in it either!
Protip: Always run some kind of filter if you care about the engine. If you need to know about restrictions run a gauge between the filter and turbo inlet! They even sell little poppets which pop to tell you when you've passed a certain vacuum threshold on ebay!
I picked up 30WHP at the 550whp level with a cutout off the 3" downpipe vs. a 3.5" full over axle exhaust.
If I picked up 30whp....my torque when up too.
There is no reason for a properly sized filter to offer any restriction to be in the slightest bit concerned about. And yes, smooth airflow will be better than turbulent airflow.
And ITB's dont always make more power....they can be tuned and setup to make more power on some applications and yes indeed plenum boxes and filters can be an important integral part of an ITB setup vs running them completely open...but again, generically they do not simply make more power.
