Standard bore 5.3 rings?
Old Apr 2, 2018 | 09:15 PM
Bad Apache's Avatar
Default Standard bore 5.3 rings?
I don't ask many questions around here. Most are easily attained through the advanced search function. But this one is alluding me. I would like to run Nitrided steel top rings and Napier steel second rings. I would reuse the stockers and just regap, but some are already too wide. Anyone know a supplier or have another recommendation based on experience with them? 3.78 in bore 1.5, 1.5, 3.0mm package.
The build is just a stock '05 5.3, with a cam and springs. 550-650whp should get the car to the numbers I want to run. So I'd guess 15-20psi range. Running E85 and A/A intercooler. Any other info needed, just ask.
Old Apr 2, 2018 | 09:56 PM
1FastBrick's Avatar
For the those you may want to see what little john is using.
Old Apr 2, 2018 | 10:15 PM
3 window's Avatar
How many do you need? I think I’ve got a couple top and second rings layin around.
Old Apr 3, 2018 | 07:24 AM
Bad Apache's Avatar
How many stockers? I quit measuring after the 3rd cylinder had .030 top ring gap. That was out of 4 measured. Strangely the second ring gaps were tighter .026-.028.
Old Apr 3, 2018 | 07:34 AM
Bad Apache's Avatar
Let me add, I don't mind buying rings. This engine was high mileage and the rings looked like crap. Just want to get something that'll live in that environment like the stockers do.
Old Apr 3, 2018 | 07:38 AM
JoeNova's Avatar
Restricted User
I gap my top rings to .030" and 2nd ring to .026". I've never butted rings in an LS before, even at 20+ PSI on pump gas.
Old Apr 3, 2018 | 08:07 AM
Bad Apache's Avatar
And you debunked the myth that a larger top gap than second gap will "unload" the top ring and cause excessive blowby! That's what I like about this site, guys have tried about everything.
Old Apr 3, 2018 | 08:24 AM
JoeNova's Avatar
Restricted User
I don't run a PCV either. Open valve cover ports with no filters. No blow-by, ever.
Old Apr 3, 2018 | 08:50 AM
Bad Apache's Avatar
Guess I need to measure them all again.
