Calling all turbo daily drivers
- I've never seen a build with a 160 stat actually run at 160. I think it will run hotter than that forever. But my stuff with 160s cools quicker.
- I'd say 150F and higher IATs most tuners will be reducing timing. 175F definitely have a bunch of timing out of it. 113 would not bother me.
- Your glowing tube video made me decide to wrap mine when done.
- I think once you check your tables, fan should not run unless it's just that hot. I've seen sometimes some setup get hot and stay out but there were a lot of factors... unwrapped stuff, underhood temps were insane, pusher fans not puller... Nowhere for the heat to go.
This may also work. I was playing with a junk thermo and took it apart completely. It still blocks the bypass port and warms up quick. Cooling ok in my mustang anyway. shouldn't really need any wizardry. Good low temp thermo with a nice radiator and fan setup. This stuff will only help marginally in my experience.
And yes John, I can confrim that with my own experience that whatever temp value the T stat is; it seems to be a good 20* hotter that it actually runs. Yesterday after putting in the 160*F Tstat, I went for a 30 mile trip down the highway and saw temps that were USUALLY 178*F for most of the drive, occasionally went up to 185*F....... I have a blanket on the turbo, the manifolds are wrapped also. I had the crossover pipe wrapped until recently. Can't see a difference either way with that one.
Ambient temp was 88*F
In terms of IAT I only way 18*F higher IAT MAX than ambient on my drive yesterday. Currently running with no hood or inner fenders.
Forcefed: I recognize that HF red pick!
I'm also curious about the heater ports... Can you still run a heater with the freeze plug in place of a T-stat???? I'm going to probably end up knocking a freeze plug in there and quit dicking around with Tstats...... I'd like to see about 170-180*F max ECT and I think a freeze plug may be the only way to get me there, especially once it continues to get hotter here in OK, I put the hood back on, and I equip A/C.
water.
160 started to crack open at 170*F and was open at about 180*F so you won’t usuallt see temps lower than 170s.
180 cracked open at like 185 and fully open in the 190s.
Stock opened at like 195 and wasn’t open till after 200*F.
fWIW the stock Tstat has a much larger opening size compared to the lower temp mr gaskets.
Stocker is bottom right. Only has 2 supports over the opening and the DIA is a good bit bigger.
I'm content with the operating temperatures I'm seeing with the 160*F Tstat, but still intend to experiment with getting them lower, either through drilling holes in the 160*F Tstat or just going the freeze plug route that works well for some guys like rotary and forcefed.
Sometimes i I see a high 165-169*F on the highway in cool
weather but not really during the summer. Usually
i the 180s.
I can’t say what difference it will make for anyone else’s setup. When it wasn’t super-hot out I was fine. But I’d creep to 220-225 on 100*+ days in traffic. With the LS1 pump, 160 thermo, and taurus fan on high. I switched to the LS7 water pump. (No idea if this pumps more volume. Rumor is it does, but I can’t find any data. It is like 2lbs lighter weight.) Then plugged the thermo port and rarely go over 200 now in 100*+ heat. Usually in the 178-185 range on normal temp. days and night cruising with the fan on low. I run a small 14x14x3.5” triple pass 3-row core. (fork lift radiator) Probably the nicest small core radiator I’ve seen, but It’s far from a properly sized “race” radiator.
Heater will still work fine with the bypass plug in. If you aren’t running a heater then you want those plugged. Looping them as many do has a similar effect to not running a thermo. It allows fluid to bypass the radiator through those parts. They are smaller though... so it’s not likely to cause an overheat situation. But if they are looped coolant is bypassing and the system is not cooling as well as it could. I get tapping and plugging can be a pain, so just stuff something into the “loop” to block flow and press on. I used a big wire nut last time.
As far as me wondering if the fan could be shut off at a MPH threshold in HPTuners instead of ONLY a ECT threshold. It looks like the answer is NO. Super disappointing. It sure would be nice if you could set the temps at what you want to run the thing as cool as possible around town and ALSO a MPH threshold to shut the fan off regardless of temp as soon as you're going X MPH.....
Another thought I had was to use a 7427 PCM from a stone age TBI truck as a standalone E fan controller. I have a box of em, and I can DEFINITELY get one to run a fan like I want easily.
When I'm cruising down the highway I see temps ranging from 178*F to 185*F with the 160*F Tstat in there.
What kind of coolant temp increase are you guys seeing when you make a hit and build up some boost???
I drove the truck through the Oklahoma summer and everything was just fine. Not losing any coolant, and no combustion gases detected with a CO detector in the coolant either. Super cool idea from rotary1307cc thanks for that man.
My fan setup is right on the edge of being unacceptable..... I have seen coolant go as high as 217*F while idling in traffic on a 100*F day..... Get going down the highway and temp drops and stabilizes around 178*F......
This was a huge learning experience for me and one thing I learned is that a cooling system that works in a N/A setup might not with a turbocharger factored into the equation. My 1 fan keeps me from overheating but it does get fairly warm idling on a hot day like I posted above.
1 fan that only covers 65% of the radiator and has to pull air through a FMIC and A/C condenser BEFORE it even hits the radiator.... Yeah my fan setup on my next turbo build will be OVERKILL....... Everything is working fine on this one though.
Thanks everyone for chiming in.
(Sorry to thread jack OP)
Yeah you need to block the bypass in the pump if you ditch the Tstat.
Something else to keep in mind is that if you can't get the temp up hot enough for a while you won't ever burn off the water in the oil. Hot is good, to a point.
Finally my mustang sits at 180-190 even on 100* days. Standard griffin universal radiator, surge tank, 160 thermo, Taurus fan.
Only change I made was a radiator cap. I found I was getting air caught in the lines due to the radiator cap on the RAD not being free flowing into the surge tank. I'd see really odd temps and even overheat some days... and not on others. Id bleed/burp the system and it would work good for a week. Then let the car sit a week and it would overheat. It made no sense to me. Installed a pressure relief style cap and propped the relief open. Now the cap on the surge tank regulates it all and the system doesn’t get air trapped anymore. Been working great all summer anyway. Need to do the same on the “race car” .
My fan setup is less than ideal with 65% coverage and having to pull air through FMIC, AC Condenser and then a radiator but since it does keep it cool (enough) I'm just going to leave it be. I'd add another fan next to the one I have but I piped my IC piping right in the damn way........ Oh the things you learn on piecing together your first JY turbo LSx build.
They told me to run an auxillary cooler with a fan which does very well on hot hot humid days in wisconsin.
Since i went that far i got an oil cooler as well. Both dont have a ton of airflow but they do keep the temps down it appears.
my buddy installed an oil cooler on his 572 and it did absolutely nothing to his overall coolant temperature. His issues are from air damming in his engine bay and from his electric fan setup not flowing enough.(cheaper aluminum radiator that is bigger than mine and a universal flex a lite setup). So he switched to a mechanical fan.
Every situation is different. Ive had luck by adding water wetter to 50/50 coolant on mud trucks no bs. It seems as though its a definite trial and error situation to keep the temps down for each application.
