Fuel system set up
Old Apr 17, 2018 | 04:42 PM
Lawhead's Avatar
Default Fuel system set up
Got an S480 5.3 yadda yadda
Setting up my fuel system
I wanted it to be 2 -10 feeds to each pump (AEM 380)
2 -8AN outlet into a -10 Y
-8 Y at the rails
-10 Return
With getting filters and everything to fit in rear of the car the -10 did not work
Was going to mount the pumps along the subframe but the 044 style pumps aren’t the best for pulling fuel that far
So my question is
Can I switch to a Dual -8 Feed and not become an issue?
Fuel will be E85 and the power should be right at 900-950 wheel
Old Apr 17, 2018 | 06:04 PM
Lawhead's Avatar
Old Apr 17, 2018 | 06:41 PM
svslow's Avatar
Even a single 8AN feed would be fine. That's all I run, with a 6AN return.
Old Apr 17, 2018 | 06:49 PM
Lawhead's Avatar
You feed both pumps with a single
-8??
Old Apr 17, 2018 | 07:31 PM
svslow's Avatar
Oh maybe I misunderstood. My AEM gets a -10AN off the sump and I've got a Walbro 450 in tank, they come together at an 8AN Y and a single 8AN runs to the rail. 8AN feed to the pumps should work fine.
Old Apr 17, 2018 | 07:50 PM
Lawhead's Avatar
Yes that’s what I’m getting at lol
2 8s to the rear of the pumps off the sump
Gonna run it this way hopefully it doesn’t cause any issues
Old Apr 18, 2018 | 07:08 AM
Suncc49's Avatar
If you don't mind me asking with all the fittings and such how much do you have in the dual AEM setup? I ask because Holley is making that new dual dominator pump that might be in a similar price range
Old Apr 18, 2018 | 07:13 AM
Lawhead's Avatar
With this bracket and all
Im like 320 into this set up,
Old Apr 18, 2018 | 07:42 AM
Lawhead's Avatar
Quick Google search showed them pumps being absolute trash
Old Apr 18, 2018 | 08:52 AM
JoeNova's Avatar
Restricted User
I feed dual AEM380s with a single -8AN feed. No issues, but I haven't leaned on it at all.
Old Apr 18, 2018 | 09:16 AM
Lawhead's Avatar
Yeah I can't see with each pump getting their own -8 that it'd be an issue, The pumps in reality are a -10 to -6 so so don't think it'd be an issue with the same size inlet and outlet causing vacuum,
I picked up some 90 degree -8AN filters that I think will fix my issue with space, With the other filters and such by the time you get 2 fittings on each end of -10 stuff you're taking up some space.
