3.87@198
Old Apr 22, 2018 | 05:40 PM
hellbents-10's Avatar
Default 3.87@198
Well after 17 passes on a new car we are moving forward. In BG we spun the first 3 hits, then the track came around. With a few pedal jobs and some semi clean passes we ended up with solid data.
4.02@186, pedal
3.93@197 clean pass
4.01@187 with a pedal job on a wheelie
3.87@197 killer clean pass with a soft 1.05 60ft
3.955@193 lots of pedal work on a wheelie went 1.02.
3.90@198 with a slightly greasy track.
The Baker billet heads are doing well with 150 passes under their belt.
Old Apr 22, 2018 | 05:51 PM
3 window's Avatar
Awesome! Nice work TJ. Give a rundown of the combo.
Old Apr 22, 2018 | 06:06 PM
sbcgenII's Avatar
Nice runs. Think you will get a 3.7 this year?
Old Apr 22, 2018 | 06:34 PM
Car: Bickle 70.5 Camaro. x-pro nitrous car
Trans: RPM TH400 with a ATI brake
Engine: 427 BEI turbo engine, Noonan block, BEI heads, Thomsen intake.
Fuel Management: Holley EFI, Billet Atomizer (245/700)
Garrett Gen 2 94s
The engine is the same combo as the Impala.
Old Apr 22, 2018 | 06:36 PM
We will see a 3.7 or better we are just tipping into the potential of this combo. Just look how many passes we have on it now, I think it will go 60s.
Old Apr 22, 2018 | 07:09 PM
3 window's Avatar
Outlaw 10.5 tire or 11.5 radial?
Old Apr 23, 2018 | 04:50 AM
Rudy72's Avatar
Dam now that's getting serious Results and enjoying some Hard Work!! Awesome stuff here competing with the Fastest!
Old Apr 23, 2018 | 06:12 AM
forcd ind's Avatar
That's a bad azz ride for sure.
Old Apr 23, 2018 | 06:27 AM
svslow's Avatar
What does it weigh?
Old Apr 23, 2018 | 09:14 AM
315 radial, and under 2500lbs.
Old Apr 23, 2018 | 09:26 AM
sbcgenII's Avatar
A 3.6 would be absolutely wicked. Can it do that with RvW rules?
Old Apr 23, 2018 | 09:50 AM
I think so might take a serious amount of laps and data but 70s should be no problem. We were picking up .6-.7 between laps at this event.
Old Apr 23, 2018 | 02:21 PM
scottywheels's Avatar
Nice work David and it was great to see you bud
Old Apr 23, 2018 | 05:18 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
That's great that you guys broke the record for ET (which you already held in in the Impala) and now have the MPH record too.
Can't wait to see what you guys do at Ducks's fall race.
Old Apr 23, 2018 | 09:54 PM
sillysspeed's Avatar
Awesome job!
