TT Ls or procharger bbc
Old May 18, 2018 | 10:25 AM
gula187's Avatar
Default TT Ls or procharger bbc
I'm in the middle of a engine decision. I have a chevelle project that's pretty much finished besides the engine. I'm stuck between a twin turbo Ls and a big cubic inch bbc. I want something about 8-850hp. But for the price it would cost to build a bbc bbc with that power it probably will cost the same to build a tt ls...What you guys think?
Old May 18, 2018 | 10:26 AM
JoeNova's Avatar
Restricted User
This again.....
Old May 18, 2018 | 11:24 AM
ss.slp.ls1's Avatar
Why not a TT big cube LS?
Old May 18, 2018 | 11:36 AM
TT427's Avatar
TT BBC is only option. 2 cheap 78/75 or 88/83 turbos to turn up at the track...
Old May 18, 2018 | 12:55 PM
007FJ's Avatar
If you drive it much I’d say ls for the better package at that level. If it’s mostly straight line and not driving it 60 miles each way to car events routinely then a NA bbc would get you to the power level. A mild 454 with a single turbo would be an easy choice to that power level also.
Old May 18, 2018 | 01:26 PM
99 Black Bird T/A's Avatar
What do you want to do with the car?
Do you like carburetors or fuel injection?
If you are good with carbs then the BBC might be less hassle than setting up and tuning fuel Injection for you. If your good with fuel injection then LS.
Do street ability and decent gas mileage matter? If so that favors an LS set up.
How importance is handling? Less weight is good and LS will be lighter.
Seems to me basically
Drag racing - big cube 600+ CID BBC and spray
Nostalgia / Originality / Resell value - BBC
Daily Driver - LS
Pro Tour - LS
Old May 18, 2018 | 02:04 PM
vinceI's Avatar
Very mild BBC with blow thru carb procharger.
Old May 18, 2018 | 02:06 PM
Fuhnortoner's Avatar
TT LQ4. Destroy everybody for half the price.
Old May 18, 2018 | 07:25 PM
gula187's Avatar
Its a daily driver with some grudge racing. I asked cause I know a guy selling a 502 bbc with a th400 for $5800 and my co-worker will sell me his ls3 & a tr6060 trans for $6000
Old May 18, 2018 | 08:12 PM
Game ova's Avatar
What is it about twin turbos? Is it because it sounds cool to say? 800rwhp is done daily with just a single 7875 and 365ci LS. Why make it more expensive?
Old May 19, 2018 | 01:36 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by JoeNova
This again.....
I think this generation only does research 140 characters at a time.
Old May 19, 2018 | 09:02 AM
MIAmotorsports's Avatar
If all you want is 800hp do a NA BBC. U could do a 454 BBC with a f1r carbureted fairly cheap.
Old May 19, 2018 | 09:12 AM
Game ova's Avatar
You ain't gettin 800rwhp from a NA BBC.
Old May 19, 2018 | 01:42 PM
Less lag. Smaller turbos spool faster than one large turbo. Not worth it to me, just sayin tho.
Old May 19, 2018 | 02:09 PM
MY_2K_Z's Avatar
Wrong
Old May 19, 2018 | 03:11 PM
Originally Posted by MY_2K_Z
Wrong
Comparing a single and twins of the same design & same airflow capability (turbine and compressor), the twins will spool faster. The inertia and the resistance to spinning up is proportionate to the mass and it's radius of gyration (the radius at which you can put the whole mass of the rotating assembly and have something that acts the same way, making calculations easier), actually by the square of the radius of gyration * the mass'¦ in other words, making the diameter of the wheel larger causes a bigger changing in inertia then anything else.
That being said, the twins will spool faster, but a smaller wheel of the same design tends to be less efficient.
When it comes down to it, we're discussing 'big V8's' which make plenty of torque making lots of boost off the line a more of a problem then an advantage and optimum will be the most efficient setup that will supply the air you need to make the power you want to make and can be packaged in the engine bay. (in other words, the least number of big turbos that you can fit/plumb)
Old May 19, 2018 | 05:40 PM
B18B1LS1's Avatar
Not the route I would choose but, why not?
Old May 19, 2018 | 05:48 PM
Game ova's Avatar
It's just hard to do. Unless it's some high strung mountain motor, it won't do it. Here's an example in the vid, motor makes 1100 on the stand..... and i can assure you, he paid a kings ransom just to make that. The average joe ain't putting down 800rwhp na. Can it be done..... yes. But the vast majority of people can't afford to do so. Just go small LS turbo and be done with it. This isn't BBC but it's close enough in Cube size.
Old May 19, 2018 | 06:03 PM
B18B1LS1's Avatar
Small block LSX is apples to oranges with a BBC. With his engine budget you could probably build 3 800hp big blocks.
Old May 19, 2018 | 06:06 PM
Game ova's Avatar
Here's the thing, that lsx with similar cubes I'm sure is more efficient than just a plain Jane BBC 454, and it doesn't eclipse 800rwhp by much. And know this, that guy has the latest and greatest of EVERYTHING in his motor setup.
