Huron Speed F-body TT builds?
I know I seen a few people on the group purchase for a TT kit as well as just receiving mine I decided to try and do a search to see if I could get some info on a Fbody build using there V2 or V3 kit but it’s hard pressed to find any info for lil stuff like which rad hoses work the best, fans had most clearance and so forth. I seen a good bit of the Vette stuff but not so much on the Fbody stuff. So anyone out there in the build process using this kit?
LS1Tech Sponsor
Hey Scott, shoot me an email with any questions you may have as well and I would be happy to assist!
For the radiator you can run a single or dual pass on the twin kit, I ran a single pass on my car with it. I cut off the upper inlet and welded on a 90* aluminum tube so the inlet ran to the center of the engine bay, parallel with the top of the radiator. Once it got to just left of center I welded on another 90* to turn towards the engine, from here I had a straight shot with some rubber hose to the water pump. I used some flexible tubing on the lower hose to the T-stat. For fans I ran a pair of Derale #16925's as pushers, they hung onto the end tanks some but that is no issues as a pusher and kept the car extremely cool.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
