Best intake for BOOST?
Old Jun 8, 2018 | 12:43 PM
LS1924's Avatar
Default Best intake for BOOST?
hi guys! I have a Gen IV 5.3 with forged pistons and rods, going to be running twin 6266 turbos, I had purchased a FAST 92mm intake a while back before I got all the Engine work done, I was recently told that that intake won’t work (not recommended) for my setup since it’s a 2 piece design and plastic and all that. My power goals are 1000hp. I still don’t have heads either, so I’m open to cathedral or rectangle port (also open to head suggestions). I was told to either run a stock intake or some sort of aluminum intake. What do you guys think/recommend would be the best intake manifold for my setup?
Old Jun 8, 2018 | 12:46 PM
JoeNova's Avatar
Restricted User
Stock.
Old Jun 8, 2018 | 01:11 PM
LS1924's Avatar
Originally Posted by JoeNova
Stock.
so LS6?
Old Jun 8, 2018 | 01:12 PM
JoeNova's Avatar
Restricted User
Pretty much any of them.
Old Jun 8, 2018 | 01:18 PM
LS1924's Avatar
so the stock ones are better than the aftermarket? Do you know why?
Old Jun 8, 2018 | 01:22 PM
JoeNova's Avatar
Restricted User
Because when your turbos are deciding how much air to force feed the engine, it doesn't really matter how much air it was able to swallow on its own.
Almost all of the stock intakes have been in the 7s. LS1, LS6, Truck, etc. They're cheaper, fit better, easier to find, weigh less, heat soak less, take fewer special fittings, and you probably already have one somewhere.
Old Jun 8, 2018 | 01:23 PM
Forcefed86's Avatar
Depends what you want to rev it to... below 6k all the OEM units are hard to beat. TBSS truck intake being the best I'm aware of for a cathedral port. If you plan run the RPM up past 6800ish.... start looking at aftermarket.
Old Jun 8, 2018 | 01:24 PM
LS1924's Avatar
alright cool! Sounds good. I actually don’t have no haha, wish I did. Not sure what do with this FAST intake now either..
Old Jun 8, 2018 | 01:25 PM
LS1924's Avatar
hmmm ok ok, and if I do go past 6800ish what would be a good aftermarket intake?
Old Jun 8, 2018 | 01:29 PM
JoeNova's Avatar
Restricted User
Stay away from the Chinese fabricated intakes. Headaches, bad fitment, lots of weird noises, sometimes they blow apart, and you'll see almost no real gains with a turbo.
Even with intakes like the Holley Hi-Ram or Edelbrock Pro-Flo, you're looking at about 500 RPM worth of gains compared to losses everywhere below that. Decide if the up top gains are worth the cost and effort, where your shifts will fall to, where you will launch. Even then, intakes like the gen 4 truck intake will beat out most aftermarket intakes as the all-around performer.
Old Jun 8, 2018 | 01:32 PM
Forcefed86's Avatar
Depends how high U want to rev it and how much money you have. Shorter the runner the higher the range in general. So something like a Holley high ram would be a good place to start. You can spend $600 to 3000+ on a custom sheet metal deal. On stock block stuff I can't see spending the money.
The NEW cheapie JEGS/SUMMIT china short runner intakes are the route I'd go if anything. Usually give up 30-40 NA HP in general below 6k with them. But if you plan to rev it to 8k like these SBE guys are doing these days it seems like an OK option to me.
Jegs sells them for $379 now I believe. But you need to price out a throttle body, fuel rails, etc as well. So it can get spendy quick.
These are pretty heavy duty, not likely to split or anything weird IMO.
THIS IS THE NEWER DESIGN CONSTRUCTED OUT OF 3MM THICK ALUMINUM AND ARE RATED TO OVER 30lbs OF BOOST.
https://www.jegs.com/i/JEGS-Performance-Products/555/513050/10002/-1?CAWELAID=230006180040252396&CAGPSPN=pla&CAAGID=4 4693592161&CATCI=aud-67754331191:pla-215314521911&CATARGETID=230006180039219312&cadevic e=c&gclid=EAIaIQobChMIypu07tjE2wIVA7bACh2zzwJ8EAQY AyABEgJcvPD_BwE
Which is the same dang thing as the china stuff on EBAY I think...
https://www.ebay.com/i/262776964318?chn=ps
Old Jun 8, 2018 | 01:35 PM
JoeNova's Avatar
Restricted User
The NEW cheapie china short runner intakes are the route I'd go if anything. Usually give up 30-40 NA HP in general below 6k with them. Jegs sells them for $379 now I believe. But you need to price out a throttle body, fuel rails, etc as well. So it can get spendy quick.
These ar epretty heavy duty, not likely to split or anything weird IMO.
https://www.jegs.com/i/JEGS-Performa...yABEgJcvPD_BwE
Have you see the dyno graphs on the new low-pro china intakes?
They shift power so high, most guys aren't revving high enough to see any gains over a stock truck intake. Even the taller versions were only gaining at 6500+.
Holdener recently did another one of his massive intake tests, but this time with boost. I won't spoil the surprises (since he hasn't publicly shared the results), but I'd recommend avoiding the headache of the china intakes and just get the cheapest one that works.
Old Jun 8, 2018 | 01:44 PM
Forcefed86's Avatar
I have, and I agree, but power from 3800 to 5800 isn't where I have an issue. I'm usually just fighting traction there and have to dumb down the tune to plant the tire. The new trend seems to be big RPM and the OEM intakes aren't happy much past 6500. (none of mine are anyway) Not that it won't go there... but if I was shooting for 1000+hp on a "built" 5.3 I'd want to rev it out pretty good. A hood that closes it s plus too. The truck stuff takes up alot of space.
Old Jun 8, 2018 | 02:26 PM
Detoxx03's Avatar
Stock intake is all you need
Old Jun 8, 2018 | 06:06 PM
stevieturbo's Avatar
Depends how far past 6800rpm lol. And depends on your budget, your heads, cam, valvetrain...and what room you have, etc etc
Old Jun 8, 2018 | 06:10 PM
I think Camaro Andreas ran 6's with a ProFlo...and more recently in a more sedate build, this guy is doing wonders with one, on a street build ! And he's using a tad more than 7300rpm...He's definitely getting to 8000rpm ?
Think his previous posts he had used the Holley race Sniper intake ?
https://ls1tech.com/forums/forced-in...rk-needed.html
Old Jun 8, 2018 | 06:13 PM
Looks the same as them all really, Holley included. The image looks like the Holley, although their height stats sort of suggest a lower profile shorter runner.
With hindsight...I sort of wish I'd bought the ProFlo, the quality on the Chinese is just poor, although their heights are more user friendly.
Old Jun 8, 2018 | 06:22 PM
LS1924's Avatar
So maybe you guys can help me figure out the RPMs, or is that something you figure out when you rest the vehicle? I’m going to be running a complete C5 setup with T56 in the rear.
