Siphoning Meth/H2O @ low ?
Old Jul 1, 2018 | 09:47 AM
dlandsvZ28's Avatar
Originally Posted by NitrOmm
Thanks JimmyG, that was my next question.
As as a precaution I dropped the reservoir lower than the nozzle. I intend to give it try in a few hours. This is just a bandaid. That is the 1/2 assed way to deal with this ... but I’m truly not in the mood to drill a new hole, plug the old & move the nozzle.
Ultimatly a $60 precaution such as this can save me some agrivation.
Can you give me any advise on the wiring & instal.
-What triggers the solenoid ? ( same MAP sensor wire ?).
- is it positioned on the high pressure side (just before the nozzle) or between tank & pump.
This valve answers my question in previous post (will some mechanical one way valves open due to suction). This one looks like an easy install and less complicated. Reasonable in price as well.
http://www.alcohol-injection.com/en/...eck-valve.html
It still surprises me that any vendor would sell or design a methanol system without a check valve or strongly advise to install one. It's costing me around $12k because I didn't have one as well as another in OK who didn't have one either.
Old Jul 4, 2018 | 02:59 PM
jimmyg's Avatar
Mine is installed right after the pump . 2 wire hook up. Ground, then hot wire hooked up to pump hot. Solenoid is triggered with pump.
Old Jul 4, 2018 | 03:02 PM
JoeNova's Avatar
Restricted User
My Nova would siphon mine just slightly. Probably a quart every few hundred miles. Seeing as how the intake ports, valves, and pistons were almost spotless, I let it go haha.
Old Jul 5, 2018 | 03:02 PM
NitrOmm's Avatar
I just ordered a check valve from Alky Control. Inexpensive & simple to mount.
After dropping my reservoir a few inches, effectively making the nozzle higher than the fluid level, my siphoning issue went away. Driveabilty improved & the stumble in the lower RPM range went away. The check valve has a 10# pressure prerequisite. That should do the trick & then I can retire my new ZIP TIE bracket system for the reservoir.
Thanks for everybody's help !!
Old Aug 25, 2018 | 09:27 AM
NitrOmm's Avatar
An update:
check valve in ..... problem solved.
I put my windshield washer reservoir back in position & all is well.
