90* coil boot ends??
Old Jul 15, 2018 | 03:23 AM
Cwarta's Avatar
Default 90* coil boot ends??
Does anyone make a 90* boot for the coil pack end of an ls coils? Have forward and up manifolds, plug wires keep getting burnt. Thanks
Old Jul 15, 2018 | 08:39 AM
JoeNova's Avatar
Restricted User
Can you use long wires, or are you looking for short straight ones?
Old Jul 15, 2018 | 11:04 AM
Cwarta's Avatar
I was wanting to 90* straight back towards the firewall from the coils and wrap around the back of the manifolds and come back forward to each plug
Old Jul 15, 2018 | 11:19 AM
350SS's Avatar
i think taylor makes some, did a quick search and saw 45deg ones at least...search for lt1 (the older one) style coil ends and there are more options than the ls style ends
Old Jul 15, 2018 | 11:42 AM
JoeNova's Avatar
Restricted User
I don't know if they will work for that.
Look up "Blue Streak LS Plug" on ebay. Super heavy duty plug wires used on the LS2 engines in NASCAR.
If you look hard enough, you can see them going completely around some up and forward truck manifolds on my buddy's truck:
Old Jul 15, 2018 | 01:12 PM
Cwarta's Avatar
Those look like a great option!
Old Jul 15, 2018 | 03:49 PM
JoeNova's Avatar
Restricted User
I guarantee you won't find anything even close to that nice for double the price. They're no joke.
Old Jul 15, 2018 | 09:46 PM
Lsxford's Avatar
The bluesteak wires are great! I did burn a few of those tho. I did similar to what op is wanting to do, I used a cut to fit kit with 90 plug ends and bought the universal ls1 coil boot set. They are not 90* ends but are kinda flexible so I just pulled them to 90* and secured them tightly so they won't move. I'll get a pic tomorrow to show.
I was working on an 8.1 liter 2500 the other day and noticed they have the LS style coil boots but are considerable longer than LS wires. I would guess 10 inches at least. The Ford 6.2 also uses the same coil end and are around 10 inches long iirc, it is a 16 spark plug job.
Old Jul 17, 2018 | 06:48 AM
jzales's Avatar
I had the same problem with my cx racing kit and ended up going with accel ceramic booted lt1 wires. No problems since.
Old Jul 17, 2018 | 08:59 AM
fif_gen_powa's Avatar
I kept burning up plug wires, ended up just using some exhaust heat wrap on any plug wire that was close to the manifold I wrapped around it really thick to insulate it and has been fine ever since
Old Jul 23, 2018 | 11:02 AM
frojoe's Avatar
Taylor and MSD offer a "soft bend" 90* end, which is intended for an LT1 distributor end, but the terminal works for an LS coil. I personally don't like the look of, but they're these...
What I ended up doing is using those straight LT/LS terminals and 90 degree distributor boots which are super tight and compact..
I just install the wire and straight terminal into the tight 90* boot with a bit of dialectic grease, and have the terminal protrude about 1/4" which is enough to get the boot to seat on my truck coils and have the terminal click into place...
Old Jul 23, 2018 | 01:01 PM
Cwarta's Avatar
I ordered a set of the blue streaks, they are monsters! However I’m not sure they will work how I want them too. These look like a good option!
Cwarta's Avatar
Also where did you get those firewall grommets?
Old Jul 23, 2018 | 02:36 PM
frojoe's Avatar
Yeah after ~6 years I haven't seen any kinking or damage to the plug wire from making it bend kinda sharply inside the tight 90* boot.. so it's all good I think.
I machined those firewall grommets years ago... they're one of the first things people ask about haha.
Old Jul 23, 2018 | 05:26 PM
Cwarta's Avatar
They look great! Well done!
Old Jul 23, 2018 | 05:50 PM
frojoe's Avatar
Thanks!
Old Jul 24, 2018 | 03:48 PM
Stonerracing's Avatar
  1. Im in the same boat. Trying to figure out the best way to route my spark plug wires. Ive thought about running short ceramic tip wires through the middle with lava sleeves. Or back to firewall than back up.
Old Dec 10, 2023 | 06:22 PM
fusion_ta66's Avatar
Bringing this back from the dead. Are there any options with a 90* boot on the coil side? Assemble-your-own OK and maybe actually preferred since I need a very short length.
Old Dec 10, 2023 | 07:42 PM
gjohnsonws6's Avatar
Call Firecore and tell them what you want, the possibilities are endless.
Old Dec 11, 2023 | 05:14 PM
frojoe's Avatar
I used a Taylor 83051 which has 90* ends on both ends:
https://www.summitracing.com/parts/TAY-83051
If you want just the 90deg boots/ends, there is also Taylor 46067 which is "for LT1 distributor" so they're a compact/tight 90deg:
https://www.summitracing.com/parts/TAY-46067
