Not building boost
Old Aug 1, 2018 | 02:40 PM
Mavn's Avatar
"I MAID THEESE"
Nice Kit kindof looks like mine! What brand Gate and what Location?
Old Aug 1, 2018 | 02:44 PM
ledesordre's Avatar
Originally Posted by Luke19901
just put compressed air into signal port using a regulator and slowly wind it up. you'll soon see if the spring or seat is no good. or if the diaphragm is torn. saves you removing and stripping it if there's nothing wrong.
you definitely cant hear any exhaust gas out the screamer pipe at idle?
I have the wastegate exit feeding into the downpipe, but I can't hear anything like that
Edit: will try the regulator compressed air later.. assuming I do that after I remove the wg to physically see if the diaphragm is opening.
Old Aug 1, 2018 | 02:45 PM
ledesordre's Avatar
DIY kit using tial 38mm mvs mounted just before the hotside enters the turbo
Old Aug 1, 2018 | 03:06 PM
Mavn's Avatar
"I MAID THEESE"
HM strange. all of your V Bands are on good?
Old Aug 1, 2018 | 03:19 PM
ledesordre's Avatar
Yes they look solid, nice and tight, I don't see any carbon staining escaping where there would be if there was a significant leak
(Did have that issue before but already addressed)
Old Aug 1, 2018 | 03:33 PM
Kfxguy's Avatar
You may not have this issue but I had a hard time welding my v band clamps on the thicker stuff and keeping them from warping. As a matter of fact I’ve got to just weld one of them together because it warped. Sucks because I would be able to take the turbo off very quickly but now I can’t.
Old Aug 1, 2018 | 03:42 PM
Dimeomboost's Avatar
Hate to be that guy but I don't see any one else saying it. U can go back and look at some of my threads and see where I had the same turbo as u and the exact same issue your problem is the turbo is junk I had the 76mm and the 88mm on3 I had less than 12hrs on the 76mm I took it straight to rpm. In Raleigh and it wouldn't build boost chased all kinds of things looking for a fix hooked there gauge straight to the turbo housing made a pull and nothing. The inner seal or seals not sure I'm not an expert on turbo internals but it was pushing oil into one side and letting pressure through it's not a good explanation but I don't tune or build turbos it's just how they dumbed it down to me. Put an s476 on it no other changes besides the t6 flanges and it runs beautiful
Old Aug 1, 2018 | 03:54 PM
ledesordre's Avatar
Interesting :/
Old Aug 1, 2018 | 04:26 PM
Kfxguy's Avatar
Interesting :/
I’m not sure I’d worry about that. It’s probably something your over looking. Besides, the only person I know personally that has on3 turbos on their car works with me and she’s never had a problem with them. Newer 5.0 that runs mid 9’s.
Old Aug 1, 2018 | 04:53 PM
ledesordre's Avatar
yeah stuff like that just makes it harder to troubleshoot. I do have one of their very first 76mm. It has almost no miles though. About to try a pressure check.
Old Aug 1, 2018 | 06:01 PM
ledesordre's Avatar
OK I made an air regulator, ran about 20 psi to the tial 38mm mv-s wastegate, I can hear it actuate. It sounds like metal on metal, is that normal? Uploading a video for you guys--- before I find time to pull the WG off completely.
Check it out, let me know what you guys think
Old Aug 1, 2018 | 06:41 PM
  #32
Loud Mouse's Avatar
Default On3 twin 70s
And no problems so far. Only been 8 months but I ride at 2900rpm for long periods of time. Something simple ur overlooking. GL
Old Aug 1, 2018 | 07:01 PM
  #33
Luke19901's Avatar
can you pressurise the entire charge air system inputting where the air filter bolts on to rule out and boost leaks.
Old Aug 1, 2018 | 07:08 PM
  #34
ledesordre's Avatar
I’ll have to buy a block off at home depot for the air filter compressor housing inlet, going to give it a shot though. Then I’ll run some psi into the fitting on the compressor housing.
Would that only test the cold side, though?
Old Aug 1, 2018 | 08:24 PM
  #35
Luke19901's Avatar
no it should flow through your cooler, past the BOV into the TB and inlet manifold. then it will leak out the exhaust through the open valves. but your compressor will flow enough to negate whats leaking out the exhaust and you'll be able to inspect the entire charge air system for leaks. it will also check the BOV is sealing at the same time
Old Aug 1, 2018 | 08:57 PM
  #36
ledesordre's Avatar
OK I blocked off the air filter inlet, and pumped about 10-20 psi into the compressor housing. Not detecting any leaks that way.
I'm using a 1.0 a/r exhaust housing but I think it would still spool. I'm not getting any spool but no apparent leak on the hotside either.
Old Aug 1, 2018 | 09:26 PM
  #37
Luke19901's Avatar
what MAp sensor, MAF, PCM and tune is in your car currently?
Old Aug 1, 2018 | 09:30 PM
  #38
Kfxguy's Avatar
What size pipe do you have coming off your manifolds going to the turbo? Maybe the spring is too soft.
Old Aug 1, 2018 | 09:31 PM
  #39
ledesordre's Avatar
Stock until I can get the turbo spooling, then I will get it ready for the tune.
Old Aug 1, 2018 | 09:44 PM
  #40
ledesordre's Avatar
2.5" off each c6 manifold, merges into 3" right before the turbo
