Not building boost
Old Aug 1, 2018 | 09:46 PM
  #41
Luke19901's Avatar
its possible that its far too lean to make the turbo spool or a torque limit is hindering it from spooling.
it only has a one bar MAP sensor on no SD cheat patch to make that work. it has no fueling reference for boost except the MAF which will be miles from calibrated now being turbo.
I wouldn't rule out the stock tune causing you issues be it only that or be it that's its contributing to something else hindering your spool efforts.
do you have HP Tuners?
Old Aug 1, 2018 | 09:53 PM
  #42
ledesordre's Avatar
Definitely appreciate that insight. I have been trying to figure this out for a while. I do not have HP tuners but contemplating getting it for some time now. Might be time to pull the trigger.
Old Aug 1, 2018 | 09:59 PM
  #43
Luke19901's Avatar
plenty of guys that can answer questions and guide you to help you learn.
Old Aug 1, 2018 | 10:17 PM
  #44
JoeNova's Avatar
Restricted User
Remove the wastegate and test it with an air compressor. You'll want to actually see the valve opening.
Old Aug 2, 2018 | 07:42 AM
  #45
ledesordre's Avatar
Will give it a shot.
Old Aug 2, 2018 | 08:20 AM
  #46
ledesordre's Avatar
d'oh!
Old Aug 2, 2018 | 08:46 AM
  #47
Cwarta's Avatar
I can’t see the image :/
Old Aug 2, 2018 | 08:57 AM
  #48
ledesordre's Avatar
it just shows the new hp tuners pro not being available yet
Old Aug 2, 2018 | 12:49 PM
  #49
ledesordre's Avatar
Video of Wastegate bench test. Should there really be daylight around the valve?? Also took more psi that I expected to get it to actuate.
Old Aug 2, 2018 | 12:54 PM
  #50
MY_2K_Z's Avatar
You can see all the carbon on the flange it's definitely leaking like hell. Doesn't look like the fire ring was ever installed
Old Aug 2, 2018 | 01:17 PM
  #51
ledesordre's Avatar
i had the wrong clamp on it for a while but that should be resolved as of a while ago hopefully. I’ll keep an eye on that. I’m more concerned with where you can see daylight through, any opinion on that?
Old Aug 2, 2018 | 01:19 PM
  #52
ledesordre's Avatar
Also towards the end of the video
Old Aug 2, 2018 | 01:23 PM
  #53
MY_2K_Z's Avatar
The fire ring isn't in there so basically there is no valve seat. But you do have the fire ring right?
Old Aug 2, 2018 | 01:27 PM
  #54
ledesordre's Avatar
Old Aug 2, 2018 | 01:31 PM
  #55
ledesordre's Avatar
I made the kit myself so I wouldn't be surprised if I messed something up. I have the exit of the wg pointed into the downpipe.
Old Aug 2, 2018 | 01:35 PM
  #56
3 window's Avatar
There’s no fire ring dude!
Old Aug 2, 2018 | 01:38 PM
  #57
3 window's Avatar
The dark grey ring is this picture is the fire ring. It’s not in your video or your pics. It’s a separate piece that you put in the gate before securing it to the hot side.
Old Aug 2, 2018 | 01:40 PM
  #58
ledesordre's Avatar
Nice man---- sounds like a winner. I bought the Wg used off here so not surprised it was missing something...
Old Aug 2, 2018 | 01:48 PM
  #59
ledesordre's Avatar
http://www.tialsport.com/documents/explodedmvs.pdf
fire ring/valve seat was missing
Old Aug 2, 2018 | 02:29 PM
  #60
MY_2K_Z's Avatar
Let us know how it runs with the fire ring, you said you were still on the stock tune but I wouldn't run it without atleast a 2 bar base tune. As soon as it makes boost it's going to go extremely lean and more than likely melt the pistons or detonate and break it.
