How long for a tune?
Old Aug 22, 2018 | 04:37 PM
blackandgold's Avatar
Default How long for a tune?
I know this has been hashed out at least a few times, but I'm trying to manage expectations here. The same shop that is tuning the car did all of the engine work.
Relevant info:
-installed D1SC boost should be ~7lbs
-installed kooks headers + true duals
-deleted EGR and AIR
-replaced a bunch of gaskets
-Fuel is a racetronix pump + hotwire through AUS 65lb injectors
Car is an M6 with ~145k miles on the stock LS1
The car started being tuned, but they can't get it to idle so far replaced the IAC, TPS and a rotted vacuum hose behind the intake. I know that it's a high mile car and things can happen, how long would you expect a shop (procharger dealer) to get something like this sorted out?
Old Aug 22, 2018 | 04:42 PM
Toes's Avatar
How are they trying to tune it? With or without the MAF? Speed density? Could take awhile if there are other gremlins that stop them from getting started.
Old Aug 22, 2018 | 04:52 PM
With the MAF, sounds like there are no problems with the WOT tune, but at idle when warm it'll stall out. They've already had the intake off and it sounds like that was how the found the dry rotted vacuum tube, but that didn't help.
Old Aug 22, 2018 | 06:03 PM
HCI2000SS's Avatar
I think you know my thoughts on this lol
Old Aug 22, 2018 | 10:30 PM
I do, unfortunately I got pulled out of town this week. I'm not looking forward to potentially towing it to another shop...
For anyone curious why I'm asking, tuning started last Wednesday.
Old Aug 22, 2018 | 11:02 PM
Game ova's Avatar
You can pull the car from them, but what sucks is...you will have a bill from them as well as whatever shop you take it to. Bad deal.
Old Aug 23, 2018 | 06:59 AM
Suncc49's Avatar
Since you are paying someone else to do work on the car you will be into this for alot potentially.... they own this problem as the car ran and idled fine before their install and tune. I would try to come to an understanding that you aren't paying for diagnosis and repair of an issue they created with the install.... Install cost and tune of course should be paid. You really are at their mercy though and they could charge you extra labor for diagnosing issues from their own work/tune....
Old Aug 23, 2018 | 07:58 AM
HCI2000SS's Avatar
I totally understand. Not sure if it matters or not but that shop and my guy are about 10 miles apart. Just thought I'd throw it out there in case
Old Aug 23, 2018 | 08:30 AM
Fair, I'm hesitant to drop him a car that might need more than just a tune at this point.
Old Aug 23, 2018 | 08:43 AM
ddnspider's Avatar
WOT is fine but it won't idle????LOL. Vacuum leak or bad tuner. Does it have a huge cam or something?
Old Aug 23, 2018 | 08:46 AM
HCI2000SS's Avatar
Good point. He just does tuning
Old Aug 23, 2018 | 09:19 AM
Stock cam and low boost. Also since i didn't mention it before, the car ran great when I dropped it off otherwise I wouldn't be boosting a high mileage LS1. It sounds like at this point I might not be crazy for thinking > 1 week for a tune is getting a little on the longer side. Per the invoice I've got they're also charging me $950 for just the tune which seemed high, but I figured for getting a great tune done quickly it'd be worth it...
Old Aug 23, 2018 | 09:27 AM
stoverz28's Avatar
$950 is a crazy high price for a tune.
Old Aug 23, 2018 | 09:50 AM
ddnspider's Avatar
So it ran well when you dropped it off...they put a blower on it and now can't get it to idle. Did they bother updating the VE and MAF tables and commanded idle airflow??? It takes more idle airflow to turn a blower.....but that should be tuning 101.
Old Aug 23, 2018 | 11:43 AM
Suncc49's Avatar
500.00 for full dyno tuning is the going rate around here... edit but that includes a base tune so you can get to the dyno lol
Old Aug 23, 2018 | 11:49 AM
JoeNova's Avatar
Restricted User
Sounds like a bad tune. Probably don't know how to get the minimum pulsewidth down on a stock PCM.
I'd expect it to come back with an extra 200 RPM idle speed as their quick fix.
Old Aug 23, 2018 | 10:55 PM
dlandsvZ28's Avatar
If they are a reputable ProCharger installer they should have discovered the vacuum leak when they installed the D1 as they would have had to test vacuum and have a good source of vacuum for the ProFlow to keep it open at idle or let it close at boost. Sounds like they just sells things.
Probably don't have the vacuum line to the ProFlow hooked up right as it is very hard to get it to idle if that line is leaking.
Old Aug 24, 2018 | 06:06 AM
Matt_ws6's Avatar
$950 is ridiculous for a tune. I recently got my car re-tuned and it was $330, 150 an hour plus tax.
Old Aug 24, 2018 | 07:48 AM
mightyquickz28's Avatar
Did they upgrade the injectors, switch to a new MAP sensor?
If the injectors were changed and are substantially larger,
  1. Hopefully the injector data has been entered correctly
  2. If the data is correct, and it's running rich at idle, they might need to drop the minimum fuel milligrams in the transient fuel tab (at least that's what I did to tame my 127# Bosch in HP Tuners). Stock value was 0.041 and ran rich no matter what I did to any VE(speed density tune, 3 bar) but changed it to 0.020 and it cleaned right up.
If the MAP was changed, hope they have the correct Linear and offset coded in. If not, they'll be chasing their tails for days.
Old Aug 24, 2018 | 09:46 AM
Injectors were definitely upgraded to 65# AUS injectors. I have no idea if the MAP was updated to be honest. I'll be giving them a call today and try to figure out what my options are. If at the end of the day they aren't capable of tuning the car it's going to need to go to someone else. I've already missed the Woodward dream cruise, but there is a car cruise on Sundays in Pittsburgh that I'd like to hit while I'm home at my parents over labor day.
